Re: Wide block 318 & Regular 318-timing covers the same?
[Re: High Impact]
#624147
02/25/10 04:44 PM
02/25/10 04:44 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
You need the pre 70's smallblock cover to match the timing mark location on your early harmonic balancer. If you use a later cover, you need the later harmonic balancer, and of course the coresponding years waterpump.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
