Wide block 318 & Regular 318-timing covers the same? #624143
02/25/10 03:44 PM
02/25/10 03:44 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I have an old BB 318 thats missing the timing chain cover. Can I use the newer style from the late 60's to mid 70's? Are the bolts holes the same. Thanks!
Re: Wide block 318 & Regular 318-timing covers the same? [Re: High Impact] #624144
02/25/10 04:10 PM
02/25/10 04:10 PM
Alton, IL
Dakota_Don Offline
Dakota_Don  Offline
Alton, IL
first there is no such thing as a wide block, and the covers are different,
but i am sure they will work, i think the only thing thats different will be timing locations,,
if im wrong please corect me..
Re: Wide block 318 & Regular 318-timing covers the same? [Re: Dakota_Don] #624145
02/25/10 04:38 PM
02/25/10 04:38 PM
Andrewh Online content
Andrewh  Online Content
you are looking for a pre70's timing cover if you are planning on using the pre 70's pump.
Should bolt up just fine.
Re: Wide block 318 & Regular 318-timing covers the same? [Re: Andrewh] #624146
02/25/10 04:43 PM
02/25/10 04:43 PM
scratchnfotraction Offline
lots of stuff swap over t-chain cover being one of them
they are good canidates for a ssteel crank for the LA 318 also
LA will bolt on the same tranz and vice versa
Re: Wide block 318 & Regular 318-timing covers the same? [Re: High Impact] #624147
02/25/10 04:44 PM
02/25/10 04:44 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
You need the pre 70's smallblock cover to match the timing mark location on your early harmonic balancer. If you use a later cover, you need the later harmonic balancer, and of course the coresponding years waterpump.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
