brake issue maybe
#624000
02/25/10 01:47 PM
02/25/10 01:47 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
i had drum brakes on my car and after i would run the car several times down the track they would start sticking and smoking
put willwoods on the car now and they seem to be doing something similar. so now i'm thinking i have a proportioning valve or something causeing the issue but i'm not that knowledgable to know what it could be.
also, looking for holley 750 dp base if anyone has one. pm me please
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: brake issue maybe
[Re: quick77rt ]
#624002
02/25/10 03:34 PM
02/25/10 03:34 PM
sixpackgut
Charleston
its a new style master cylinder. i dont think thats the problem. it just seems like pressure doesnt release in the back brakes
[Re: sixpackgut]
#624004
02/25/10 03:53 PM
02/25/10 03:53 PM
Posts: 7,506 Az
Crizila
Az
If you went from drum to disc on the rear you can'r use the same prop valve. You will have to go with an aftermarket adjustable prop valve.
Fastest 300
[Re: Crizila]
#624005
02/25/10 10:19 PM
02/25/10 10:19 PM
sixpackgut
Charleston
found the problem. anyone care?
[Re: sixpackgut]
#624009
02/25/10 11:27 PM
02/25/10 11:27 PM
Posts: 6,343 SE PA.
QuickBpBp
SE PA.
the problem was the rubber hose from the hard line to the rear. i took it off and it looks like a solid piece of rubber. not collapsed, swelled solid. replaced it with a new one i had laying around for front brakes and it works perfectly now. hope my 1.38 60 ft times improve
Well then I was kinda right. They can deteriate inside. That what I was talking about. Collapse or swell shut.....
[Re: Crizila]
#624011
02/26/10 04:19 AM
02/26/10 04:19 AM
quick77rt
Parts Problem
Parts Problem
Really...Ive hit them hard at over 130 with ww on the fronts and dr diffs fords on the Dana as well as the big bore MC from DR Diff...oem porp. Stops on a dime, and my WW adjustable valve is sitting in its of box collecting dust. Good to seee you sorted it out six pack, my next question was has it been towed recently...I had a ride towed one time and they hooked the rear axle and on the brake hard line, crushed them and made them lock and slow to release. Glad you found the problem before it caused any major hurt. Quote:
