who sells heater duct hose for A bodies? #623912
02/25/10 12:55 PM
02/25/10 12:55 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
thanks
68 dart 383/727/3.55
Re: who sells heater duct hose for A bodies? [Re: revcon] #623913
02/25/10 01:37 PM
02/25/10 01:37 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
Ride eternal, shiny and chrome
Re: who sells heater duct hose for A bodies? [Re: DirectSubjection] #623914
02/25/10 02:19 PM
02/25/10 02:19 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
just remember, the ports on the box are different size than the ports on the dash vents. and I think on A-bodies the 2 ports on the box are different sizes as well
Re: who sells heater duct hose for A bodies? [Re: gtx6970] #623915
02/25/10 03:42 PM
02/25/10 03:42 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
Does any one make reproduction heater duct hose that are the right size and all?
Re: who sells heater duct hose for A bodies? [Re: revcon] #623916
02/25/10 03:43 PM
02/25/10 03:43 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
I have an A/C set, but they are too short for non A/C
Re: who sells heater duct hose for A bodies? [Re: revcon] #623917
02/25/10 05:18 PM
02/25/10 05:18 PM
Southern Maryland
klunick Offline
klunick  Offline
Southern Maryland
Thought I bought mine from Paddock.
67 Barracuda FB 69 Superbee "Southern Maryland: If you want a good looking woman, you had better bring her with you"
Re: who sells heater duct hose for A bodies? [Re: klunick] #623918
02/25/10 05:27 PM
02/25/10 05:27 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
Thanks, I'll check them out.
Re: who sells heater duct hose for A bodies? [Re: revcon] #623919
02/25/10 07:49 PM
02/25/10 07:49 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
Try www.RosevilleMoparts.Com they seem to be a little cheaper in price that some of the other guys.
Re: who sells heater duct hose for A bodies? [Re: RBSat66] #623920
02/25/10 11:55 PM
02/25/10 11:55 PM
Pewaukee, WI
Airgrabber Offline
Airgrabber  Offline
Pewaukee, WI
Re: who sells heater duct hose for A bodies? [Re: Airgrabber] #623921
02/26/10 07:34 PM
02/26/10 07:34 PM
PA, USA
moparpilot1 Offline
moparpilot1  Offline
PA, USA
napa and it's cheap
Re: who sells heater duct hose for A bodies? [Re: moparpilot1] #623922
02/26/10 09:58 PM
02/26/10 09:58 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
You got a part number or anything? The folks at the two NAPA locations nearest me (including the area distribution center) are about as good as the local AutoZone in terms of knowledge and customer support (I miss being near a good NAPA).
Re: who sells heater duct hose for A bodies? [Re: Chilort] #623923
02/27/10 07:52 AM
02/27/10 07:52 AM
Mass
charge70 Offline
charge70  Offline
Mass
Contact Chet Greenwood at Chet's Auto Parts.He did have a stock of NOS heater hoses for non a.c. A-Bodies.His contact info is; 401-397-1825. He should be able to hook you up. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: who sells heater duct hose for A bodies? [Re: charge70] #623924
02/27/10 11:17 AM
02/27/10 11:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I took the riginal heater duct hose from my 65 Cuda down to Pep boys and just matched it up with the in stock stuff.
It ain't rocket science. If you ain't got the original duct then measure the openings and go to the store.
Don't be the exception.
Re: who sells heater duct hose for A bodies? [Re: charge70] #623925
02/27/10 06:07 PM
02/27/10 06:07 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
Thanks, I called Chet's and he wants $100. I don't have a show car, so that is out of my budget. He also told me that the A/C ones I have should be the same? Can anyone confirm this?
Re: who sells heater duct hose for A bodies? [Re: revcon] #623926
02/27/10 06:30 PM
02/27/10 06:30 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
$41.00 for the set at RosevilleMoparts.com
Re: who sells heater duct hose for A bodies? [Re: revcon] #623927
02/27/10 06:31 PM
02/27/10 06:31 PM
Stow,Ohio
RBSat66 Offline
RBSat66  Offline
Stow,Ohio
$41.00 at RosevilleMoparts.com
Re: who sells heater duct hose for A bodies? [Re: RBSat66] #623928
02/27/10 10:28 PM
02/27/10 10:28 PM
media, Pa
revcon Offline OP
revcon  Offline OP
media, Pa
I finally found them at roseville. Not an easy website to locate things easily. Thanks.
