Stall or tranny or normal? #623832
02/25/10 10:07 AM
02/25/10 10:07 AM
South Carolina, United States
carolinacuda Offline OP
Hey guys im wondering is it normal for the trans to slip alot after the car has been parked for a while. I have to rev motor pretty good to get the car to move (foward or reverse)when its cold. It takes a while to warm up. Ive always heard with a high stall u need to put trans in neutral when first starting up and let it run for a while, to let fluid circulate i guess (mine is a 3800 stall). When i drove it the other day after being parked for couple months it seemed to have alot of slipping. This is just when taking off from a stop. Is this a sign of stall going or trans prob or is it normal? The prob faded away as it warmed up.
Re: Stall or tranny or normal? [Re: carolinacuda] #623833
02/25/10 10:11 AM
02/25/10 10:11 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
ALWAYS warm your hot rods up in neutral. I warm all my vehicles up in neutral actually. Don't forget to block a tire.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Stall or tranny or normal? [Re: bigsbigelow] #623834
02/25/10 10:21 AM
02/25/10 10:21 AM
ky
68roadrunner Offline
ky
is the fluid dark and burnt smelling
Re: Stall or tranny or normal? [Re: 68roadrunner] #623835
02/25/10 10:35 AM
02/25/10 10:35 AM
PA
moparacer Offline
moparacer  Offline
PA
Doesnt sound right to me. I think you got problems somewhere.
2 months setting should in no way make anything slip trans or converter related.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Stall or tranny or normal? [Re: carolinacuda] #623836
02/25/10 10:52 AM
02/25/10 10:52 AM
NC
chris3 Offline
chris3  Offline
NC
We have a reverse valve body and 3800 stall. I asked about this and was told that you should shift from park to neutral to allow the fluid to circulate then shift to either forward or reverse. Been doing ever since we change to stall converters.
Re: Stall or tranny or normal? [Re: chris3] #623837
02/25/10 11:25 AM
02/25/10 11:25 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had this problem years ago with my TA converter. My dad spoke with TA and they said it was the converter draining back because it was getting worn out. They said putting it in nuetral before putting it in gear would help and it did. I did that for a few months with good success and then the snout broke off
68 Barracuda Formula S 340
Re: Stall or tranny or normal? [Re: 68roadrunner] #623838
02/25/10 02:23 PM
02/25/10 02:23 PM
fluid looks good. I also have reverse valve body (cheetah) with a TCI converter and yes i know i need a new one. Im working on gettin a new one as soon as i get the $$$$. Next time i will go through all the gears. I just normally leave it in neutral for a few mins.
