Re: 70 cuda 340 - finally painted!
[Re: Barnabas_Kriss]
#623715
06/22/11 03:57 AM
06/22/11 03:57 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
I also got the exhaust system done. 2-1/2" all stainless steel including all clamps, hangers, hardware. All mandrel bent pipes, X-pipe removable with V-clamps in case transmission or clutch need to be changed. This was done by a local shop, it was expensive, but top quality work.
#623721
06/25/11 12:38 PM
06/25/11 12:38 PM
Posts: 1,300 Washington
19cuda73
Washington
Turning that key for the first after such a great build must be pretty exciting. Your doing a first class job. Keep the updates coming. Dennis ![](/ubbthreads/images/graemlins/beer.gif)
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
#623729
07/06/11 04:14 AM
07/06/11 04:14 AM
Barnabas_Kriss
After having some problems with the EFI and clutch, today I got it all sorted out, and took it for a test drive! There are still some adjustments needed with the ECU, but it is totally driveable as is. Also the belt tensioner I made came apart after about 5 miles, the outer aluminum ring came off the bearing due to heat expansion. Made one out of steel with a much tighter press fit, all seems OK now. Also have a problem with the lower rad hose, once everything warms up, it expands a bit and it it too close to the belt. I'll get this sorted out this week. Otherwise the car drove fine, no strange noises, brakes worked well, clutch is a little grabby, but not too bad. The EFI hemi is definitely superior to an old school carbureted engine. I hope to take it for a longer test drive very soon.
Here is a pic of the completed engine compartment.
