Page 1 of 13 1 2 3 12 13
70 cuda 340 - finally painted! #623491
02/25/10 02:19 AM
02/25/10 02:19 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline OP
Here are some pictures of my 70 cuda 340. I've been working on it for about 4-5 years. It was a complete non-running car when I bought it, has been sitting since 1979.
Origianlly a 340 4-speed, 3.91 axle package, rally dash, hood pins, console, black interior, road lamps, etc. Have the original fender tag and broadcast sheet.
I am restoring the body and the interior to stock, add a few options (rear louvers and rear spoiler) and upgrading the drivetrain. It will have a small block stroker, W2 heads, Tremec 5-speed, plus suspension and brake upgrades. I keep it pretty much bolt on stuff, so could be returned to stock in the future.
It needed plenty of metal work, floor pans, 1 full quarter, 1 lower quarter, trunk floor, tail light panel, inner fenders, etc. I used all original mopar sheetmetal. The body has been dipped (Redi-Strip) and zinc phosphated. I did all the metal work myself, as well as the undercarriage painting. The exterior was done by a local painter, who does excellent work.
Here it is as purchased.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623492
02/25/10 02:21 AM
02/25/10 02:21 AM
Body shell dipped and metal work in progress.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623493
02/25/10 02:22 AM
02/25/10 02:22 AM
More metal work.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623494
02/25/10 02:22 AM
02/25/10 02:22 AM
2
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623495
02/25/10 02:23 AM
02/25/10 02:23 AM
3
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623496
02/25/10 02:23 AM
02/25/10 02:23 AM
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623497
02/25/10 02:24 AM
02/25/10 02:24 AM
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623498
02/25/10 02:24 AM
02/25/10 02:24 AM
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623499
02/25/10 02:26 AM
02/25/10 02:26 AM
All seam cleaned, welded solid, and re-leaded.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623500
02/25/10 02:26 AM
02/25/10 02:26 AM
New lead.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623501
02/25/10 02:28 AM
02/25/10 02:28 AM
After electrolytic de-rusting and zinc phosphate coating (also done by Redi-Strip).
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623502
02/25/10 02:29 AM
02/25/10 02:29 AM
Body in epoxy primer.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623503
02/25/10 02:29 AM
02/25/10 02:29 AM
More primer.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623504
02/25/10 02:30 AM
02/25/10 02:30 AM
Undercarriage ready for prep and paint.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623505
02/25/10 02:31 AM
02/25/10 02:31 AM
Undercarriage painted.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623506
02/25/10 02:32 AM
02/25/10 02:32 AM
Undercarriage close-up.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623507
02/25/10 02:32 AM
02/25/10 02:32 AM
Close-up #2.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623508
02/25/10 02:37 AM
02/25/10 02:37 AM
Test fitting of panels and trim.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623509
02/25/10 02:38 AM
02/25/10 02:38 AM
Test fit #2.
Re: 70 cuda 340 - finally painted! [Re: Barnabas_Kriss] #623510
02/25/10 02:40 AM
02/25/10 02:40 AM
Exterior paint, just finished about two weeks ago, in the original color, FK5 burnt orange, done in base clear, wet sanded and polished. I'm very happy with the outcome. I'm very excited to finally begin assembly!
