Anyone try the new VP 113 Race fuel?
#623180
02/24/10 08:32 PM
02/24/10 08:32 PM
VP just introduced a new race fuel that is oxygenated VP 113 which will replace the 110 octane fuel and make more power. you'll need to jet up about 2%-3% with this fuel. I'm liking this alot for my 500 ci Indy motor.
Re: Anyone try the new VP 113 Race fuel?
[Re: Rodney]
#623183
02/24/10 09:59 PM
02/24/10 09:59 PM
from what I learned about the oxygenated fuels the down side is they are corrosive to your fuel system and if the car sits for any length of time one should flush the system. Also needs tin containers so the fuel stays fresh. that and the price helped me decide to go with C-14
unless im missing something, oxygenated fuels are being dispensed in all the gas stations these days and we are using oxygenated fuels in our daily drivers with no issues. whats different about this oxygenated fuel. for a all out race cars, i like the added power this fuel will make.
#623186
02/25/10 01:38 AM
02/25/10 01:38 AM
Posts: 43,215 Bend,OR USA
Cab_Burge
the pump gas has Ethanol alcholol, maybe the race gas has Methanol. Both types of alcholol will suck moisture out of the athomspere, unless it is sealed up tight. Methanol and water mixed end up making sulpheric acid, is what I have been told I used to mix Methanol(23%) with race gas along wth Toulene and Acetone, it needed be jetted up a lot, my fuel sytem was't good enough to allow mo fatten the jets up enough to slow the car down then hindsight is great I ended up blowing a head gasket, ruining the block and the head because it leaned out in the summer IHTHS
[Re: B G Racing]
#623188
02/25/10 08:27 PM
02/25/10 08:27 PM
maybe ill run 2 gallons at a time and drain my system after each weekend.
[Re: B G Racing]
#623189
02/25/10 10:03 PM
02/25/10 10:03 PM
Challenger 1
Cincinnati, Ohio
One of our racers found out the hard way,after letting his car set all winter with oxygenated gas his entire fuel system and $1400 carb were oxydized with a white powder corrosion and pitting.
IMO If your gonna run it, you might as well run alky.
I remember being flamed when I warned about leaving alky in your race car for long periods. Wonder how it worked out for some of those guys?
[Re: Challenger 1]
#623190
02/25/10 11:45 PM
02/25/10 11:45 PM
cant run alky in NSS.
