Re: Leaf spring resto....???
[Re: cdp]
#623167
02/24/10 11:22 PM
02/24/10 11:22 PM
Posts: 2,938 California
1970mopar
California
I'm looking for longevity, and very close to OE look.
That's very difficult to achieve.
Most Leaf Springs were bare heat treated spring steel.
Painting or powdercoating will protect them the best, but will only be close to original look. Spraying with a matte clear will only slow the rusting process. They will eventually rust
[Re: Paul Jacobs]
#623170
02/27/10 12:01 AM
02/27/10 12:01 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Personally, I would tear them apart and rebuild them with the new kits out there. They are good and the process is fairly easy. As Paul mentioned, the '69's I've seen have been black, so that sort of makes it easier to look OEM.... I did the ones on my '68 Hemi Charger R/T and they came out nice. In '68, they, for the most part I have found, where natural. I cleaned and wire brushed mine, shot them with Permatex Extend for corrosion control and then shot them with a matte clear. Then I proceeded to put the springs back together with a new rebuild kit. Make sure, if you can, to save the bolts that go through them. They are unique with the round head and each side is of a different length.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#623173
02/27/10 12:12 AM
02/27/10 12:12 AM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
what if you need them re-arched? can you use a press? or is there a special process?
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: Paul Jacobs]
#623175
03/03/10 06:23 AM
03/03/10 06:23 AM
Posts: 98 Poplar Bluff, Missouri
S&J Butler
So if you powder coat them will the heat from the oven not harm them in any way? Also anyone know what color 70 E-body springs were from the factory?
1970 Challenger 1973 Satellite 400 1974 Barracuda 1988 D-150 (LE-150) SWB 2010 Crew cab Hemi Ram 2019 Crew cab Hemi Ram
