Bell housing bolts #622919
02/24/10 03:57 PM
02/24/10 03:57 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
Where can I find the correct Bell housing bolts and are those painted? this is for a stock 383. Thanks
Re: Bell housing bolts [Re: 70 buzz] #622920
02/24/10 04:19 PM
02/24/10 04:19 PM
WI
RestoRick Offline
RestoRick  Offline
WI
Bell Housing Bolts
Painted with bellhousing bolted to engine...
Rick
Re: Bell housing bolts [Re: RestoRick] #622921
02/24/10 04:47 PM
02/24/10 04:47 PM
michigan
70 buzz Offline OP
70 buzz  Offline OP
michigan
thanks Rick
Re: Bell housing bolts [Re: 70 buzz] #622922
02/24/10 05:50 PM
02/24/10 05:50 PM
Mass
charge70 Offline
charge70  Offline
Mass
Painted only with a manual trans,original plating if mated with an automatic trans. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Bell housing bolts [Re: 70 buzz] #622923
02/24/10 09:31 PM
02/24/10 09:31 PM
WV
Little Detroit Offline
WV
I have them in stock. Give me a call.
Re: Bell housing bolts [Re: Little Detroit] #622924
02/24/10 09:36 PM
02/24/10 09:36 PM
So Dak
GOLDENCOMMANDO Offline
So Dak
