Is this normal rust area??? #622882
02/24/10 03:46 PM
02/24/10 03:46 PM
Northern VA
1970440six Offline OP
Northern VA
I tinkered with my Roadrunner today and discovered a few rust holes on the lower left quarter panel. Somebody had replaced the rear quarters on the car but did a very bad job and as
I was inspecting today I noticed rust holes.
It is actually on the rear of door jamb behing where the factory quarter panel goes. Is it normal to get rust there or do you think that if it has rusted there the entire rocker panel will need replaced?
Re: Is this normal rust area??? [Re: 1970440six] #622883
02/24/10 03:49 PM
02/24/10 03:49 PM
Northern VA
Northern VA
on the right side of the picture you can see the replacement panel. The left side show the remainder of factory panel, I burned the lead solder out.
Re: Is this normal rust area??? [Re: 1970440six] #622884
02/24/10 03:52 PM
02/24/10 03:52 PM
Northern VA
Northern VA
If you look closely you can see 3 rust holes in the metal under where the factory panel was. Just wondering if this would be somewhat normal and be alright to fill holes insted of replacing rocker panel?
Re: Is this normal rust area??? [Re: 1970440six] #622885
02/24/10 04:02 PM
02/24/10 04:02 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
The lead sucks moisture in. Not suprised its rusted.
Re: Is this normal rust area??? [Re: 1970440six] #622886
02/24/10 05:23 PM
02/24/10 05:23 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
What happens is any rain water that seeps past the rear window seals runs down the inside fo the quarter. There are a couple of drains stamped into the quarter to allow the water to drain out. But it will wick up in-between the joints where the quarter joins the rocker. Over time it will rust, especially since there is no paint there, just the dipped primer. So to answer your question, yes, you can get rust there. The best way to fix is to remove and patch.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Is this normal rust area??? [Re: RemCharger] #622887
02/24/10 06:16 PM
02/24/10 06:16 PM
Northern VA
Northern VA
There isn't any damage where the lead was, it is behind the quarter panel below door jamb. In fact the metal behind the leaded seem is perfect even where the quarter panel meets the roof,
I removed that lead and there is no pitting.
Re: Is this normal rust area??? [Re: RoadRunner] #622888
02/24/10 06:20 PM
02/24/10 06:20 PM
Northern VA
Northern VA
The metal behind there looks structural, is it ok to cut and weld new metal in or should the entire rocker panel be replaced?
Re: Is this normal rust area??? [Re: 1970440six] #622889
02/24/10 06:40 PM
02/24/10 06:40 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Thats a very common rust spot. Cut it out and weld in a new peice of metal.
