Motor "diesels" after shut off #622524
02/23/10 11:29 PM
02/23/10 11:29 PM
Paris, Tx
mopartruckguy Offline OP
Paris, Tx
What would cause your motor to try to keep running after shutting it off other than timing and high idle speed?
Re: Motor "diesels" after shut off [Re: mopartruckguy] #622525
02/23/10 11:42 PM
02/23/10 11:42 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Start by turning the idle speed down. You can also turn the ignition off while in gear,rather than in neutral.
Re: Motor "diesels" after shut off [Re: mopartruckguy] #622526
02/23/10 11:49 PM
02/23/10 11:49 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Causes for dieseling can be
Idle mixture is off, either too lean or to fat a mixture can be a cause
Carbon build up causing a hot spot
Carb not closing completely
Too high an idle
Incorrect timing
Not necessarily in any order
Ken
Re: Motor "diesels" after shut off [Re: mopartruckguy] #622527
02/24/10 12:24 AM
02/24/10 12:24 AM
glowing carbon or metal shard in the cc
Re: Motor "diesels" after shut off [Re: RapidRobert] #622528
02/24/10 12:54 AM
02/24/10 12:54 AM
MNobody Offline
MNobody  Offline
Bad Gas.
Re: Motor "diesels" after shut off [Re: mopartruckguy] #622529
02/24/10 03:52 AM
02/24/10 03:52 AM
places
79powerwagon Offline
places
Your throttle plate isn't closing all the way.
Re: Motor "diesels" after shut off [Re: 79powerwagon] #622530
02/24/10 11:35 AM
02/24/10 11:35 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Yup,
Need more intial timing which will allow you close the throttle blades more at idle.
Re: Motor "diesels" after shut off [Re: Challenger 1] #622531
02/24/10 04:40 PM
02/24/10 04:40 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
GOOD food-for-thought ... but when I have encountered something like this .. it has been carbon build-up that is glowing.
TRY fogging some water down the carb ... that might loosen up the carbon. Back when I had this issue ... a 400 in a duallie with lots of miles .... WATER INJECTION straighened out the situation directly.
It was almost a MIRACLE how this process would actually CLEAN UP a carboned-up spark plug I threw in there just as a test.
Re: Motor "diesels" after shut off [Re: dOoC] #622532
02/24/10 07:30 PM
02/24/10 07:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Only way that timing can effect the dieseling problem is that the timing can effect the idle speed and the most common cause of engine run on is too fast an idle speed.
Timing in itself cannot create engine run on (other than effecting idle speed). All electrical power to the ignition is off.
Re: Motor "diesels" after shut off [Re: MoparforLife] #622533
02/24/10 09:31 PM
02/24/10 09:31 PM
Paris, Tx
Paris, Tx
Thanks guys, yall are always a big help!
Re: Motor "diesels" after shut off [Re: dOoC] #622534
02/25/10 12:07 AM
02/25/10 12:07 AM
MNobody Offline
MNobody  Offline
No kidding? would that clean up valves and unstick rings? is it safe? Just use a squirt bottle or what? sorry to hijack but that sounds like good info.
