Re: 440 SOURCE ALUMINUM HEADS
[Re: BUTCH123]
#622205
02/23/10 09:21 PM
02/23/10 09:21 PM
Posts: 2,126 Hunt Valley, Maryland
1fastrunner
ANY COMMENTS ON USING 440 SOURCE HEADS ON MY MOTOR? IM BUILDING A 60 OVER BALANCED 440 509 PURPLE SHAFT CAM AND LIFTERS DON'T KNOW INTAKE YET BUT WOULD LIKE TO RUN HILBORNE ELECTRONIC FUEL INJECTION. THANKS IN ADVANCE
Stop shouting, all the haters will hear you and chime in. Mine are fine so far. Jim
[Re: 1fastrunner]
#622206
02/23/10 09:31 PM
02/23/10 09:31 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Like any after market part, it's best to have it checked prior to use.
[Re: pinkduster]
#622211
02/24/10 07:59 AM
02/24/10 07:59 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
No problems with mine after 2 years.I had them checked and springs etc changed for my cam.Any aftermatket head has to be checked before install.Rocky
Chrysler Firepower
[Re: crscuda]
#622212
02/24/10 10:42 AM
02/24/10 10:42 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
GTXKEN What problem did you have with your heads?
The valve job was poor, installed heights of springs were off and valve guides were tight. Like I said its all good now but I should have spent a little more up front and got a better set of heads.
[Re: GTXKen]
#622213
02/24/10 01:39 PM
02/24/10 01:39 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Those issues should be expected with any out-of-the-box heads. Regardless of price level or brand. Indy, Edelbrock, 'Source... they all will have similar issues.
[Re: moper]
#622214
02/24/10 03:23 PM
02/24/10 03:23 PM
Posts: 996 Queens, New York
Harley
Queens, New York
100%
[Re: Harley]
#622215
02/24/10 03:42 PM
02/24/10 03:42 PM
WILD BILL
BROOK PARK, OH
100%
Make that three
Post deleted by moparts
[Re: chrisf]
#622217
02/24/10 05:20 PM
02/24/10 05:20 PM
[Re: chrisf]
#622218
02/24/10 05:27 PM
02/24/10 05:27 PM
Posts: 4,041 michigan woods
imfixinmopars426
michigan woods
dont buy the 440source heads. in the short term you will think your saving money but long term you will have more into them than a set of RPM heads. at least i do.
i really would like to run them on my 500 im collecting parts for stock look,but. ..you know.."i never remember those 440's running THAT good" i would pay ede prices IF they would be a quality piece...and the one that are having issues,please list the issues,that you had with them,and im NOT wanting to bash 440source,cust service ect...just the issues with them, and making them a realiable performance part.
[Re: ireland383]
#622220
02/24/10 06:59 PM
02/24/10 06:59 PM
therocks
Niles , Ohio
I have about 500 in my Source heads.Id have the same in the Eddys.Mine would have been ok out of the box if I wasnt running such a radical cam and 4 speed.Mine only needed the valse touched up because my machinist is a perfectionist.Id of had that much and more in Eddys because I would have had to had my pistons cut to clear the dome pistons.My shop was impressed with my heads.As he said not a full race head but nice for the price.Rocky
Chrysler Firepower
[Re: therocks]
#622221
02/24/10 07:18 PM
02/24/10 07:18 PM
Posts: 2,473 Sydney,Australia
tex013
Sydney,Australia
very happy with mine,been on about 18 months. had to clearance them for 3/8 pushrods.pocket port and set valve heights,cut the deck to match my iron 906 combustion chamber - 78cc.even used supplied springs.i am using the 509 cam,m1 single plane manifold numbers are in my sig by the way even after this work i still had less in them than a set of eddys. Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
