Good Mopar shops near WI? #621920
02/23/10 04:30 PM
02/23/10 04:30 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Any recommendations on a reputable Mopar shop in Wisconsin? The closest shop to me that I have found so far is Best Machine in Michigan.
Re: Good Mopar shops near WI? [Re: mopar873] #621921
02/23/10 04:53 PM
02/23/10 04:53 PM
Oak Grove, MN
lowflyingdart Offline
Oak Grove, MN
Lofgren Auto Specialties in MN. Winner of the 2005 Royal Purple Engine Challenge
763-753-7573
www.lofgrenautospecialties.com
"I have not failed. I've just found 10,000 ways that won't work." Thomas A. Edison
Re: Good Mopar shops near WI? [Re: lowflyingdart] #621922
02/23/10 04:56 PM
02/23/10 04:56 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi,
where are you in Wi, and what type of work did you need done, ie; body or mechanical, chassis?
thanks
Russ
Re: Good Mopar shops near WI? [Re: mopar873] #621923
02/23/10 05:06 PM
02/23/10 05:06 PM
good ole USA
moparlifer Offline
moparlifer  Offline
good ole USA
Check out "Chenowethspeedandmachine.com" which is Mopar only located in Central Illinois.
Re: Good Mopar shops near WI? [Re: moparlifer] #621924
02/23/10 05:19 PM
02/23/10 05:19 PM
Az
Crizila Offline
Crizila  Offline
Az
Opel Engineering, just outside of Chicago. (630) 837-2900 - Ted.
Fastest 300
Re: Good Mopar shops near WI? [Re: Crizila] #621925
02/23/10 05:25 PM
02/23/10 05:25 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Kilpatrick Racing Engines in Waukesha WI Jim is a great guy and very good!!!!!
Re: Good Mopar shops near WI? [Re: mopar873] #621926
02/23/10 05:49 PM
02/23/10 05:49 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
It would be well worth it for you to take your stuff to them( gas/shipping) that way you will know its done right
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Good Mopar shops near WI? [Re: B3422W5] #621927
02/23/10 06:47 PM
02/23/10 06:47 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
Kilpatrick in Waukesha. Absolutely one of the best. I think an internet search for kilpatrick engine and transmission is the easiest way to find him, or bad judgement racing is another way to search for Jim.
Re: Good Mopar shops near WI? [Re: mopar873] #621928
02/23/10 06:59 PM
02/23/10 06:59 PM
Wisconsin
MagnumExpress Offline
Wisconsin
Magnum Express Racing Located In Appleton, Wi. I can be reached at (920)850-6545. Let me know what you are in need of.
Jeff
Re: Good Mopar shops near WI? [Re: MagnumExpress] #621929
02/24/10 10:30 PM
02/24/10 10:30 PM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Thanks for all the posts guys. I will probably go through my engine next winter and want a good machine shop to bring my junk to.
Re: Good Mopar shops near WI? [Re: mopar873] #621930
02/24/10 10:37 PM
02/24/10 10:37 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Hey mopar873, did you happen to buy your coronet from Michigan?
Re: Good Mopar shops near WI? [Re: joshking440] #621931
02/25/10 01:23 AM
02/25/10 01:23 AM
WI
mopar873 Offline OP
mopar873  Offline OP
WI
Nope, bought the Belvie from New York
Re: Good Mopar shops near WI? [Re: lowflyingdart] #621932
02/26/10 09:52 PM
02/26/10 09:52 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
763-753-7573
x2, Chuck and Larry do awsome work.
Re: Good Mopar shops near WI? [Re: joshking440] #621933
02/26/10 11:36 PM
02/26/10 11:36 PM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Yup, I second that one! Jim is knowledgeable and very as to work with.
Mike
1969 Dodge Dart Swinger
Re: Good Mopar shops near WI? [Re: MikeyT] #621934
02/27/10 01:00 PM
02/27/10 01:00 PM
Wis.
rlm2268 Offline
rlm2268  Offline
Wis.
check out Goodwin Competition in Omro Wis.
Re: Good Mopar shops near WI? [Re: mopar873] #621935
02/27/10 02:36 PM
02/27/10 02:36 PM
Wisconsin
StillRock69 Offline
StillRock69  Offline
Wisconsin
Jeff Wick at Jim's Car Shop - Fond du Lac, WI
Re: Good Mopar shops near WI? [Re: StillRock69] #621936
02/27/10 06:53 PM
02/27/10 06:53 PM
Hibbing Mn
tazmaniac Offline
tazmaniac  Offline
Hibbing Mn
Plum Crazy Racing in Ladysmith Wi,does alot of mopars, Did Hopkins SSAH unbeleviable guy straight shooter worth the callhe has his own SSAM cuda 715 532 6320 his name is Rod Marinucci
Re: Good Mopar shops near WI? [Re: mopar873] #621937
03/02/10 04:07 PM
03/02/10 04:07 PM
WI, USA
67dodge67 Offline
mopar addict
67dodge67  Offline
mopar addict
WI, USA
Westech Auto in Silverlake, WI. They are about 15 minutes away from 'Da Grove. I used to go to a competitor who was closer to me but will never do that again. Out of respect, I wont state his name here because I don't know who frequents this site. If you are interested, PM me.
The guys at Westech will sit down with you and ASK what you want to have done and price range you want to STAY in. The other place thought it would be nice to do 'this and that' and SELL it to you before asking. I also went to Westech to fix the problems that had happened several times - I learned my lesson who I could trust.
I wont to get into the whole story here because for all I know, things may have changed. But the fact of the matter is, I found out about Westech from people I met at 'da Grove and they ALL highly recommended them.
And, Norm, the owner has been involved with mopars for atleast 30 years. Here's their website: westechauto.com
Just my
Re: Good Mopar shops near WI? [Re: tazmaniac] #621938
03/02/10 04:10 PM
03/02/10 04:10 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Gritzmacher Racing engines in Knowlton on Lake Dubay does a great job
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Good Mopar shops near WI? [Re: StillRock69] #621939
03/02/10 08:05 PM
03/02/10 08:05 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I have been dealing with Jeff at Jim's Car Shop on a business level for many, many years. He has always been an honest straight shooter that knows his stuff.
It won't cost anything to stop in and and talk to him
