Anybody tried the Zumbrotta 18 spline gearset? #621237
02/22/10 08:50 PM
02/22/10 08:50 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey there guys,
just wondering if anybody on here has tried to new 18 spline gearset from zumbrotta gear (zbag.com) and what your results have been like...They are priced at 850 for a 2.66 first gear ratio, but apparently are made from the same material as stock gears but with a better heat treating process...seems like a nice option for converting a 23 spline over to 18 with all new gears, but just wondering if anybody has tried it before i buy a set
thanks!
Matthew
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: mshred] #621238
02/22/10 11:11 PM
02/22/10 11:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hey there guys,
thanks!
Matthew
Talk to Jamie Passon about that gear set,He has had a set in the shop and also had a few customers that have installed them as well.
They are imported
Gus
64 Plymouth Savoy
Dana 60
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: fourgearsavoy] #621239
03/19/10 08:59 AM
03/19/10 08:59 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey there guys,
thanks!
Matthew
They are imported
Gus
for some reason i didnt see this until now...thanks, will do!
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: mshred] #621240
03/19/10 11:15 AM
03/19/10 11:15 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
As far as I know, that is the only stock ratio 18 spline gearset available.
I have never installed a set, but I know a couple guys who did. They didn't have any complaints.
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: DoctorDiff] #621241
03/19/10 11:52 PM
03/19/10 11:52 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I bought the lower cluster gear from them. It seems like a nice piece. We'll see if it holds up.....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: DoctorDiff] #621242
03/20/10 12:55 PM
03/20/10 12:55 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
it looks like a good peice, albeit its the only one out there so not much choice though for others...i would assume its stronger than the stock stuff since it is brand new metal, but im not sure since im not clear on where they are made
Re: Anybody tried the Zumbrotta 18 spline gearset? [Re: DemonDust] #621243
03/20/10 12:55 PM
03/20/10 12:55 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
if you dont mind me asking, who did you buy it from and for how much? i know these things list for like 850US dollars
