Re: Anybody tried the Zumbrotta 18 spline gearset?
[Re: fourgearsavoy]
#621239
03/19/10 08:59 AM
03/19/10 08:59 AM
Posts: 3,426 Toronto
mshred
Toronto
Hey there guys,
just wondering if anybody on here has tried to new 18 spline gearset from zumbrotta gear (zbag.com) and what your results have been like...They are priced at 850 for a 2.66 first gear ratio, but apparently are made from the same material as stock gears but with a better heat treating process...seems like a nice option for converting a 23 spline over to 18 with all new gears, but just wondering if anybody has tried it before i buy a set
thanks! Matthew
Talk to Jamie Passon about that gear set,He has had a set in the shop and also had a few customers that have installed them as well. They are imported ![](/ubbthreads/images/graemlins/Twocents.gif) Gus
for some reason i didnt see this until now...thanks, will do! ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DoctorDiff]
#621242
03/20/10 12:55 PM
03/20/10 12:55 PM
mshred
Toronto
As far as I know, that is the only stock ratio 18 spline gearset available.
I have never installed a set, but I know a couple guys who did. They didn't have any complaints.
it looks like a good peice, albeit its the only one out there so not much choice though for others...i would assume its stronger than the stock stuff since it is brand new metal, but im not sure since im not clear on where they are made
[Re: DemonDust]
#621243
03/20/10 12:55 PM
03/20/10 12:55 PM
mshred
Toronto
I bought the lower cluster gear from them. It seems like a nice piece. We'll see if it holds up.....
if you dont mind me asking, who did you buy it from and for how much? i know these things list for like 850US dollars
