Re: rim screw leaking air
[Re: wyldebill]
#621229
02/22/10 09:39 PM
02/22/10 09:39 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
do they make a radial race tube?
I see Hoosier and M&H offering radials that require tubes , but I don't know if they are different than a bias ply tube.
Post deleted by Defbob
[Re: wyldebill]
#621231
02/22/10 10:13 PM
02/22/10 10:13 PM
#621232
02/23/10 01:35 AM
02/23/10 01:35 AM
Posts: 3,518 pacific northwest
Stroker Scamp
pacific northwest
is the back side of the bead smooth, no burrs etc, ive had a screw leak on on of my slicks tried a new screw. tried putting the screw in with higher pressure but it just wanted to leak , so i took it out fwiw,
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: wyldebill]
#621233
02/23/10 09:58 AM
02/23/10 09:58 AM
Posts: 8,165 Left Coast
BobR
Left Coast
the radials on the car have not had screws in them only the wheel, but it looks like the hole location will not let the bead seal.
Weld up the holes and polish them out. Do you know anyone with an aluminum mig spool gun?
[Re: camastomcat]
#621235
02/23/10 03:43 PM
02/23/10 03:43 PM
Posts: 3,957 West Coast, CA
Troy
West Coast, CA
I have seen many time where the screw pushes the tire bead away from the rim. I cut down the screw by 1/8" - 3/16". This left plenty of threads to dig into the bead but it did not push the bead away from the rim.
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
[Re: Troy]
#621236
02/23/10 04:00 PM
02/23/10 04:00 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Yep what Troy said. I also picked up some screws at the local hardware that had a gasket under the head. I put a small dab of permitex and never had no problems... But Not running tubes, vs running tubes If I have them I will run them..I dont mind adding air every week or two when the get a tad low. But this is on 100% race cars..I could see it aggravating on drivers adding air what seems every time you turn around...This would be when I would use tubes though.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
