Stock location for hood pins on A body #620408
02/21/10 09:54 PM
02/21/10 09:54 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Here is a pic from my '71 Demon. I am putting a bolt-on sixpack hood on and will use pins for the front (with the hood latch). Which hole is the stock location? The hole centered in the pic with no bolt in it?
If I remember correctly my GTX used one of the fender support bolts.
Re: Stock location for hood pins on A body [Re: VITC_GTX] #620409
02/22/10 09:36 AM
02/22/10 09:36 AM
scratchnfotraction Offline
yes,I put mine right in the hole with no bolt,I knocked the whole threded part out and mounted the pin
68 Dodge Dart
Re: Stock location for hood pins on A body [Re: scratchnfotraction] #620410
02/22/10 09:43 AM
02/22/10 09:43 AM
the house on the left.
cogen80 Offline
cogen80  Offline
thats the hole. if you look under the hood there is an oval hole that should line up to that hole.
Re: Stock location for hood pins on A body [Re: VITC_GTX] #620411
02/22/10 10:09 AM
02/22/10 10:09 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I wish mine had those holes, I just guessed and put them where I liked them.
Ride eternal, shiny and chrome
Re: Stock location for hood pins on A body [Re: DirectSubjection] #620412
02/22/10 10:40 AM
02/22/10 10:40 AM
I was talking about the one for the hood bumper stop
seems thats where it fit best on my 68,mine did not have the hole outlined in blue that was posted
Re: Stock location for hood pins on A body [Re: scratchnfotraction] #620413
02/22/10 12:01 PM
02/22/10 12:01 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Right now my GTS (68) is in the garage next to my son's Dart GT (67). The other day I was looking at the fenders and realized that the 68 had a dimple where that hole is drilled and the 67 doesn't even have that area (hard to explain, but the line is straight without the triangular area for the hood pin).
Re: Stock location for hood pins on A body [Re: scratchnfotraction] #620414
02/22/10 12:43 PM
02/22/10 12:43 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
The hood bumper stop is pretty thin. IIRC, 5/16". I think most hood pins are 1/2" dia.
You may have not had the hole there (I didn't either on my Demon), but there should be a dimple there from the factory.
Re: Stock location for hood pins on A body [Re: sharpie] #620415
02/22/10 05:02 PM
02/22/10 05:02 PM
I knocked the little star threded thing out and the 1/2 hole was there...I might have opened it up,been a while..
it does have a hole bigger than the threded part,and that thing is just held on by the tangs
worked for me and seemed to be in the correct spot for the hood flat 68 Dart hood
I had looked at a few pics of the SS/AA hemi Darts and they seemd to be in that spot also,IIRC
Re: Stock location for hood pins on A body [Re: scratchnfotraction] #620416
02/22/10 07:52 PM
02/22/10 07:52 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
I'm doing the body and paint on a buddy's Duster.
We chose to do it the same way at the front, we cut off the hood bumper star-nut and we're gonna use that hole. The plan for the rear is to weld on a bracket for the pins (lift off hood).
