replacing tailshaft bushing #619588
02/21/10 12:26 PM
02/21/10 12:26 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
tranny is in the car.do i need to drain any fluid?remove 6 bolts holding housing to tranny,using snap ring pliers,spread snap ring and work housing back.is that all that is required?
Re: replacing tailshaft bushing [Re: mcmopars] #619589
02/21/10 12:51 PM
02/21/10 12:51 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
unless you want to have a shop do it that has the tool for doing it without removing the tail housing
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: replacing tailshaft bushing [Re: dusturbd340W5] #619590
02/21/10 01:16 PM
02/21/10 01:16 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i was going to take it to a shop once i got it off.i just need to get it off
Re: replacing tailshaft bushing [Re: mcmopars] #619591
02/21/10 02:03 PM
02/21/10 02:03 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well if you have the Rear of the car higher than the front you may not spill any fluid! Remove the drive shaft. block the tranny up! remove the speedo cable and gear mark where it is and the screws on the snap ring access plate.
remove the cross member. remove the six bolts. spread the snap ring and it slides right out.
Re: replacing tailshaft bushing [Re: Dodgem] #619592
02/21/10 03:10 PM
02/21/10 03:10 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
allrighty then.thanks
Re: replacing tailshaft bushing [Re: mcmopars] #619593
02/21/10 04:59 PM
02/21/10 04:59 PM
Kissimmee Fl.
Kissimmee Fl.
That's fine but if you have the right tool you do not even have to pull the tail housing off at all.
Re: replacing tailshaft bushing [Re: dusturbd340W5] #619594
02/21/10 07:36 PM
02/21/10 07:36 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
what is it called?
Re: replacing tailshaft bushing [Re: mcmopars] #619595
02/21/10 07:47 PM
02/21/10 07:47 PM
Kissimmee Fl.
Kissimmee Fl.
bushing puller
Re: replacing tailshaft bushing [Re: dusturbd340W5] #619596
02/21/10 07:52 PM
02/21/10 07:52 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
They have a tool that will work with the output shaft in the way. another to press it back in???
Re: replacing tailshaft bushing [Re: Dodgem] #619597
02/21/10 07:56 PM
02/21/10 07:56 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
thanks,i did a search looks like $100.00 for the puller.maybe i can find a loaner
Re: replacing tailshaft bushing [Re: mcmopars] #619598
02/21/10 08:08 PM
02/21/10 08:08 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
looks like you need the tail stock off as the output shaft would stick out in the way just as I thought.
Re: replacing tailshaft bushing [Re: Dodgem] #619599
02/21/10 08:10 PM
02/21/10 08:10 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: replacing tailshaft bushing [Re: Dodgem] #619600
02/21/10 08:46 PM
02/21/10 08:46 PM
Kissimmee Fl.
Kissimmee Fl.
this would work.
http://www.etoolcart.com/fordchrysler-extensionhousingbushingremover-installerjt0161a.aspx
Yes that is what I am talking about the on I have at work is a little nicer than that as it has different sleves you can change to use on different units gm/ford/mopar but much more money I have used this type and they work fine all you have to remove is the drive shaft.
Re: replacing tailshaft bushing [Re: dusturbd340W5] #619601
02/21/10 10:40 PM
02/21/10 10:40 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Looks like a cool tool... Now all you'd have to do is get the new bushing indexing right and you'd have it made...
Re: replacing tailshaft bushing [Re: screamindriver] #619602
02/21/10 10:41 PM
02/21/10 10:41 PM
Kissimmee Fl.
Kissimmee Fl.
That's no problem at all.
Re: replacing tailshaft bushing [Re: dusturbd340W5] #619603
02/22/10 11:05 AM
02/22/10 11:05 AM
sweden
cuda-sweden Offline
cuda-sweden  Offline
sweden
ive learned from fellow moparts members that the Miller tool nr,s are 6957 and 6951,but i think this Atec T-0161-A is a bit cheaper,if i remember it right.but maybe it depends of where your bying.im going for a set of these tools to as it would cost the same to leave it to a shop here in sweden.and i rather do it myself and have the tools then jada jada jada, sorry i just watched that seinfeld episode.
Re: replacing tailshaft bushing [Re: cuda-sweden] #619604
02/22/10 08:33 PM
02/22/10 08:33 PM
indiana
mcmopars Offline OP
mcmopars  Offline OP
indiana
i found i can get a housing with a new bushing and seal from cope cheaper than i can buy the tool.so ill weigh my options
