Re: replacing tailshaft bushing
[Re: mcmopars]
#619589
02/21/10 12:51 PM
02/21/10 12:51 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
unless you want to have a shop do it that has the tool for doing it without removing the tail housing
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: mcmopars]
#619591
02/21/10 02:03 PM
02/21/10 02:03 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Well if you have the Rear of the car higher than the front you may not spill any fluid! Remove the drive shaft. block the tranny up! remove the speedo cable and gear mark where it is and the screws on the snap ring access plate. remove the cross member. remove the six bolts. spread the snap ring and it slides right out.
[Re: Dodgem]
#619592
02/21/10 03:10 PM
02/21/10 03:10 PM
Posts: 1,012 indiana
mcmopars
indiana
[Re: dusturbd340W5]
#619594
02/21/10 07:36 PM
02/21/10 07:36 PM
mcmopars
indiana
i was going to take it to a shop once i got it off.i just need to get it off
That's fine but if you have the right tool you do not even have to pull the tail housing off at all.
what is it called?
[Re: Dodgem]
#619597
02/21/10 07:56 PM
02/21/10 07:56 PM
mcmopars
indiana
They have a tool that will work with the output shaft in the way. another to press it back in???
thanks,i did a search looks like $100.00 for the puller.maybe i can find a loaner
