Not all spools are created equally
#619392
02/21/10 12:31 AM
02/21/10 12:31 AM
Posts: 3,528 Kauai, Hawaii
452RT
Kauai, Hawaii
In my quest to keep my costs down I bought a nearly new (but used) 9" to replace my 9". My attempt was to sell my 9", 28 spline pinion that has 4.57 pro gears, Summer Brothers spool and buy another 9" with 4.11 pro gears, 35 spline pinion. Long story short..... The Summer Brothers Spool is splined from one end of the spool to the other side, where as the spool that came with my new center section is offset approx. 1 3/4". This makes my pass. side axle too short. My good deal just went out the door and now I have to buy axles. Just thought I would pass this tidbit so others don't make the same mistake. In the pic you can see the spool closest to camera is offset and the one in the background is not.
Re: Not all spools are created equally
[Re: abodiesonly1]
#619396
02/21/10 04:04 AM
02/21/10 04:04 AM
452RT
Kauai, Hawaii
Wouldnt another spool be cheaper than axles?
I'm thinking about swapping the spools. Just thought this would be an easy swap, guess not.
[Re: 452RT]
#619397
02/21/10 06:30 AM
02/21/10 06:30 AM
Quicktree
I would just swap them if possible.
[Re: 440Jim]
#619400
02/21/10 10:53 AM
02/21/10 10:53 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Bummer. The cost to pay a shop to resetup the gears on the spool kinda killed your cost savings. The spool isn't the expensive part, labor is. And you are going to do that to both gear sets, double... to be able to sell/use the other differential.
Pinion depth won't be touched... Swapping the spool is easy... Just gotta set backlash & bearing preload..
BTW FWIW if you were having to completely set up a 9" it is allot easier than most third members due to the pinion coming out the front & the depth is set with shims at that mating surface so your not taking bearings on & off repeatedly..
[Re: fourgearsavoy]
#619403
02/21/10 06:00 PM
02/21/10 06:00 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
Spool swap is the easiest way to rectify this issue.
