front brakes constantly sticking on 70 B body? #619344
02/21/10 12:01 AM
02/21/10 12:01 AM
Opelika, AL
JRs_Charger Offline OP
Opelika, AL
Okay, the short version is, I have a 70 Charger with the original disc brakes up front.
The calipers are the original single piston style, and the rear brakes are the original drums. It was a factory power disc car, but someone has removed the brake booster and fitted a master cylinder from a 71-74 E body.
All the lines, calipers, and master cylinder all have less than a thousand miles on them. They are a few years old however, except for the master cylinder, it's new.
My problem is the front brakes drag constantly. Almost to the point where the left wheel cant be turned by hand once the car is jacked up. The right front isn't as noticeable, but it drags too.
Any ideas whats going on here? Aside from the deleted brake booster and the master cylinder from an E body, the rest of the brakes are as they were originally.
Any ideas where i should start looking?
I would appreciate any help, thanks!
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619345
02/21/10 12:36 AM
02/21/10 12:36 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
As long as the master is a disk/drum unit it shouldn't matter in your application, unless your concern is originality,....seeing that your car was "converted" to manual disk, perhaps the swap isn't correct, linkage wise?,...sounds like residual pressure from the master is present,....are you able to pull the brake pedal up from it's current resting position?, if it's already against the frame stop, try disconnecting the pedal linkage, and jack the offending tire(s) off the ground and attempt turning,....BTW is the pedal push rod an adjustable threaded manual unit?
You got to do a little "diggin" and supply some more info
Mike
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619346
02/21/10 12:36 AM
02/21/10 12:36 AM
Take off the line at the M/C port closest to the firewall and stick a drill bit deep into the brass seat and see if you feel the springy RPV & if so pull the brass seat out w a screw & remove it or get the right M/C which will let you select the best bore size assuming that your current bore size is not ideal. Good there? might need to replace the calipers and hoses can collapse but k.i.s.s. and since both sides are having a problem I'd start w the M/C. EDIT (1st) What Dayclona said disconnect the horizontle pushrod from the pedal so the M/C piston is retracted
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619347
02/21/10 12:40 AM
02/21/10 12:40 AM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Well I just jacked my up and the last owner had the same problem,he changed all the front calipers,mount bolts,and turned rotors.Still does it and my other Bee from the 70's did it also.I'm in the process of getting the m/c and booster done,but I've heard this may not help...I'll keep you posted.I've not removed the calipers and checked the slide area of the mounts.
Also I've been wanting to replace the hoses as they will "flap over"and hold pressure and give you the same result.So jack it up,hit the brakes and get it to act up,then crack the bleeders loose and see if that helps,it could be the hoses.. Just my.
Re: front brakes constantly sticking on 70 B body? [Re: Hemiruss] #619348
02/21/10 02:50 AM
02/21/10 02:50 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
I second the recommendation to crack the bleeder on the offending wheel when you find it dragging.
That will at least isolate it between something that is holding pressure in the system [if cracking the bleeder releases the brakes] versus a mechanical hangup of the piston, sliders, etc [if cracking the bleeder has no effect].
Down to just a blue car now.
Re: front brakes constantly sticking on 70 B body? [Re: 68HemiB] #619349
02/21/10 09:53 AM
02/21/10 09:53 AM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
my friends went through this situation last summer. it ended up being the proportion valve. now you say it is original and theirs was not, but there was a problem internally with a washer that was not of the right shape that let it act as a check valve and would hold the brakes (this problem was addmitteed to by the vendors at carlisle last summer). also here is a thread that may help to diagnose.
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
Re: front brakes constantly sticking on 70 B body? [Re: macmic87] #619350
02/21/10 10:00 AM
02/21/10 10:00 AM
NJ
440challenger Offline
NJ
are the calipers just sticking? did you try tapping them with a dead blow and see if the wheel turns free? Maybe the bores are corroded. and you just new to clean them up?
Re: front brakes constantly sticking on 70 B body? [Re: 440challenger] #619351
02/21/10 10:52 AM
02/21/10 10:52 AM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
I fixed my sticky caliper by replacing the front brake hoses ('72 'cuda ) How old are your hoses ? HTH.
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619352
02/21/10 05:06 PM
02/21/10 05:06 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Be sure the calipers can travel on the pins. Remove the rotor,put the caliper back on and see if it slides the pins.
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619353
02/21/10 05:21 PM
02/21/10 05:21 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
In my experience that's usually caused by there not being a gap between the brake pedal rod and piston in the MC or booster to MC interface.
Re: front brakes constantly sticking on 70 B body? [Re: Lefty] #619354
02/23/10 12:43 AM
02/23/10 12:43 AM
Opelika, AL
Opelika, AL
Well, I finally had a few minutes to spend on it. I didn't get to check the proportioning valve, or the master cylinder, however I did notice a couple of things.
First off, cracking the brake bleeder showed that there was no line pressure on it. So I assume that the master cyl isn't sticking open now?
When I put a c clamp on the caliper piston to compress it, there was alot of resistance. It was a major pain to get the piston to go back in the bore. This was more prevalent in the left caliper than the right.
I bought the calipers as remans in 04, and the car has sat alot since. So Is it possible that these things are corroded on the inside maybe? Or something else I'm missing?
The brake lines have less than 5000 miles on them, as does the 1 year old master cylinder. The proporting valve is the original and who knows what's going on inside it, i havent pulled it yet.
Thanks again for the help guys, I appreciate it!
Re: front brakes constantly sticking on 70 B body? [Re: JRs_Charger] #619355
02/23/10 02:32 AM
02/23/10 02:32 AM
yes if you are checking the bleeders after pumping the pedal. I'm thinking calipers now.
Re: front brakes constantly sticking on 70 B body? [Re: RapidRobert] #619356
02/23/10 11:55 AM
02/23/10 11:55 AM
Wilmington, NC
donbarnes Offline
Not THAT Don Barnes!!
donbarnes  Offline
Wilmington, NC
My 95 Nissan P/U was dragging the front brakes recently, smelled like a semi going down the road. I pulled the calipers apart and the pistons had rust/crud between the area of the seal and the dust seal. They looked like some kind of hard chrome and cleaned right up on the buffing wheel- put them back together after that and they work perfectly again
Re: front brakes constantly sticking on 70 B body? [Re: RapidRobert] #619357
02/23/10 01:29 PM
02/23/10 01:29 PM
Ohio
john55 Offline
john55  Offline
Ohio
sounds like a stuck piston
The Plymouth Win You Over Beat Goes On
