Re: how far can a 318 be bored?
[Re: motomatt383]
#619244
02/20/10 10:49 PM
02/20/10 10:49 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
there seems to be alot of 318 which are 3.91 bore being bored to 4.00 which is .090...
a 340 is 4.040..you will need another .050 for a total of .130....that is ALOT.
If you want to bore that 318 larger then say .040...you should find a machine shop that can sonic test the thickness of the cylinder walls to determine how much of an overbore you bore can take safely ...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: RapidRobert]
#619247
02/21/10 12:44 AM
02/21/10 12:44 AM
dulcich
As mentioned, have the block sonic checked then you will know just how far of an overbore you can go...
Exactly & I doubt you can go from 3.91" to 4.04"
Let me correct you on this, Robert, it's been done, way back in the days before sonic testers. That said, it is probably a rare 318 block that can go that far. These days, by all means, sonic the block, and prepare to be dissappointed.
[Re: ademon]
#619251
02/21/10 09:50 AM
02/21/10 09:50 AM
Posts: 15,487 Florida
scratchnfotraction
seen lots of the poly 318 bored 90-100+ over bore but its the poly block that is the diff from what I understand cant you use a sleeve in the thin 318 block to get the 340 bore? 4" crank is the ticket with a 318 IMHO anyways
[Re: motomatt383]
#619253
02/21/10 02:38 PM
02/21/10 02:38 PM
RapidRobert
MotoMatt your Q didn't sound vague at all. I think it will depend on what thickness the sonic checker shows you. I am doing a 360 stroker w the 4" crank and some 1.560" badger flat top pistons and some 50 under rod bearings and some .054" felpros' and I am going to destroke it as much as I can w these bearings ALL to reduce my positive deck height deck so I will only have to mill the pistons slightly (plus notches). A bit different but I'm working with what I have (plus on a budget) and I mainly need more torque in my daily driver 65 dart (I'm getting no respect w the stock 318 ). I'd call your shop & see what they want to sonic check it & if it'll go .130" all you need to do is take your choice of pistons in & tell them to go ahead.
[Re: motomatt383]
#619254
02/21/10 02:51 PM
02/21/10 02:51 PM
Posts: 209 New Zealand
solidcam
New Zealand
I have done it.Would I do it again,....no.That engine failed due to oil starvation,bearing failure.You want the walls as thick as possible on any given block and go for MINIMUM oversize.That block at 130 thou oversize I believe worked but when pushed hard put alot of heat into the walls and jacket water. Stroker crankshafts have eliminated the need to gain displacement by boring a block not specifically engineered for that purpose.
[Re: solidcam]
#619255
02/21/10 03:38 PM
02/21/10 03:38 PM
Posts: 2,111 Bowie, MD
Reggie
Bowie, MD
Here is an old Mopar Muscle article about Hensley Performance. They were routinely taking 318s .090" (4" bore - same as a 360) to get 402" with a 4" crank. The 318 cores went through rigorous sonic and pressure testing before being used. Sonic checking is the only way to tell as mentioned, but 4.04" would be pushing it and I would opt for more stroke rather than trying for that much overbore.
[Re: motomatt383]
#619256
02/21/10 03:52 PM
02/21/10 03:52 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
sorry i started this posting kinda vague. i'm researching this, and i keep hearing its been done, but I've yet to hear from someone who HAS done it. I'm putting it in my '70 D-100 pickup, the engine is a 99 Magnum motor, with a dual plane intake & i just ordered my Cam, not huge just a nice improvement over stock. i don't want to get into building a stroker. yea it'd be Kool, but.
I would even more cautious with a Magnum block.Sonic test is a must over .040.
Leave the gun.......take the Cannoli's....Mike
[Re: motomatt383]
#619258
02/21/10 04:56 PM
02/21/10 04:56 PM
solidcam
New Zealand
You don't have to spend a fortune on a teen to get performance.The main thing going against you are the pistons, usually down the hole quite far resulting in low compression.Some KB'S will sort out that problem.Next the cylinder heads, for low bucks I like the the factory J castings(for a non Magnum application) cleaned up with 2.02 or 1.92 valves with new guides,springs,retainers and some machine work(do a bowl port at the minimum),some ARP rod bolts.Find some 273 solid lifter valve gear from a junker or second hand and throw in a nice solid lift cam and you will be enjoying the teen the way it should have been assembled from the factory.
[Re: solidcam]
#619259
02/21/10 06:05 PM
02/21/10 06:05 PM
Posts: 525 Durham, NC
motomatt383
Durham, NC
I'm gonna just get a set of .030 pistons, with a zero deck height. i was hoping to get it to 340std. bore specs, mostly because its easier to say its a 340 than it a 318. but I've had a couple of 340 cars & even in there wore out condition. they would run like nobodies business!! as far as the engine I've got, its a magnum so its got good heads & roller cam!
[Re: solidcam]
#619260
02/21/10 06:07 PM
02/21/10 06:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Apparently, I am the only one that reads CarCraft. They have a stroked and poked 318 article in it RIGHT NOW.
4" bore 318 is not uncommon, but as said t is sonic tested first. BTW, all you recommending a sonic test, what's you minimum wall thickness recommendation?
(funny how everyone hollers sonic test, but no one says what you need, methinks Polly has been around).
[Re: Supercuda]
#619262
02/22/10 03:35 PM
02/22/10 03:35 PM
Reggie
Bowie, MD
There is a very good discussion about sonic testing here...
