Coolant Leak Question On 2001 Durango #619149
02/20/10 09:05 PM
02/20/10 09:05 PM
Ozona, Texas
P
Paladin Offline OP
Paladin  Offline OP
P
Ozona, Texas
To All,
I was changing the oil on the wife's 2001 Durango today and noticed a coolant leak dripping on the ground. I started looking around and found the culprit. It is a black cylindrical object with coolant lines going to and from it, and it sits near the firewall on the passenger side. It also has electrical lines going to it.
My first inclination is it is some sort of coolant line diverter or valve, but I can find no reference to it in any parts house web site. Can anyone out there point me in the right direction? I can fix most anything, but it is hard to do so when you don't even know the proper name for it.
Thanks for any help in advance, I appreciate it.
May God bless America,
Paladin
1971 Dodge Charger R/T
1977 Chrysler Cordoba A35
1979 Dodge Lil� Red Express
1981 Chevrolet Corvette
1985 Chevrolet Corvette
1986 Chevrolet Corvette Roadster
1994 Lincoln Mark VIII
1998 Dodge Ram 2500 Sport V10
Re: Coolant Leak Question On 2001 Durango [Re: Paladin] #619150
02/20/10 09:28 PM
02/20/10 09:28 PM
wisconsin
mod381 Offline
mod381  Offline
wisconsin
From what you describe that is the aux coolant pump for the rear heat as the engine water pump is not strong enough to do it alone.
Re: Coolant Leak Question On 2001 Durango [Re: Paladin] #619151
02/20/10 09:36 PM
02/20/10 09:36 PM
Might be an aftermarket block heater (coolant) or an original equipment A/C coolant shutoff for when the A/C is in use you dont want hot coolant counteracting the cooling. I'd take off the heater hoses, trim them an inch, goop them w some sealant then reinstall them & clamp them tight. Or if it still leaks take it off & bypass it by connecting the 2 heater hoses w a piece of pipe and see where it is leaking & either fix it (if it is fixable) or replace it.
Re: Coolant Leak Question On 2001 Durango [Re: mod381] #619152
02/20/10 10:21 PM
02/20/10 10:21 PM
Ozona, Texas
P
Paladin Offline OP
Paladin  Offline OP
P
Ozona, Texas
mod381,
Thank you for pointing me in the right direction. What you said made sense and I started prowling around the Internet using your nomenclature. I found the OEM part through a dealership and it should get here next week.
This Durango has been a good vehicle for us, but as soon as the wife wears it out completely we are going back to our old Ramcharger. Cheaper to operate and much simpler to work on.
Again, "muchisimas gracias".
Paladin
