Any turbo'd 3G hemi's??? #618870
02/20/10 06:46 PM
02/20/10 06:46 PM
JAX FLA
Curt Offline OP
Curt  Offline OP
JAX FLA
Well?
Curt
Oh yeah...THAT'S gonna leave a mark!
Re: Any turbo'd 3G hemi's??? [Re: Curt] #618871
02/20/10 07:17 PM
02/20/10 07:17 PM
Calgary, Alberta
Turbo392 Offline
Turbo392  Offline
Calgary, Alberta
Yes, I am.
2003 Dodge Ram 1500 Turbo / Meth Injected 6.4L Hemi (392)
Re: Any turbo'd 3G hemi's??? [Re: Turbo392] #618872
02/20/10 09:07 PM
02/20/10 09:07 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I believe there is a nascar driver building a turbo charged new challenger, but not sure if its a 3g hemi or not
Re: Any turbo'd 3G hemi's??? [Re: joshking440] #618873
02/20/10 09:29 PM
02/20/10 09:29 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The nascar guy (kurt busch) is building 1970 Challenger with a Turbo truck motor aka Gen III Hemi for Super Gas
Re: Any turbo'd 3G hemi's??? [Re: Turbo392] #618874
02/23/10 11:19 PM
02/23/10 11:19 PM
JAX FLA
Curt Offline OP
Curt  Offline OP
JAX FLA
Yes, I am.
Well go ahead and spill it please...what you got?, I guess I forgot part B of the question
Curt
Re: Any turbo'd 3G hemi's??? [Re: Curt] #618875
01/27/13 10:29 PM
01/27/13 10:29 PM
JAX FLA
Curt Offline OP
Curt  Offline OP
JAX FLA
Hey turbo 392... Any progress, education you can share?
Curt
Re: Any turbo'd 3G hemi's??? [Re: Curt] #618876
01/27/13 10:58 PM
01/27/13 10:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have a Procharger on one. Thats almost a turbo lol
They run good with Boost.
Re: Any turbo'd 3G hemi's??? [Re: FastmOp] #618877
01/28/13 01:37 AM
01/28/13 01:37 AM
Toronto
mshred Offline
mshred  Offline
Toronto
From another forum where I was asking about stock bottom end hemis and turbos
http://www.youtube.com/watch?v=BwN9xrwKkXc&feature=youtu.be
The power increases are AWESOME considering how low the boost numbers are on the combo, and it being stock bottom end
Re: Any turbo'd 3G hemi's??? [Re: mshred] #618878
01/28/13 08:25 AM
01/28/13 08:25 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
I am gathering parts to build one right now. Looking to make 900~1000HP at the tire.
Re: Any turbo'd 3G hemi's??? [Re: Curt] #618879
01/29/13 11:48 PM
01/29/13 11:48 PM
Calgary, Alberta
Turbo392 Offline
Turbo392  Offline
Calgary, Alberta
Curt
Sorry, I missed this thread.
I had the engine built with a 6.1 block purchased new back in 2006. Stock bore with a re-ground stock forged 6.1 crank, Honda journals. Diamond pistons, Ferrea valves, Carrillo rods, ported 5.7 heads, 8.5:1 compression. No stroker kits existed back then. The origin 5.7 engine ran a STS turbo kit for a year until I got greedy and popped the ring land on #3 piston.
Now several years later I've built my own rear mount turbo system and 2 front mount systems for the same long block. Currently running a front mounted Borg Warner S480-96mm 1.32 a/r with meth injection, nitrous.
Re: Any turbo'd 3G hemi's??? [Re: Turbo392] #618880
01/30/13 07:55 PM
01/30/13 07:55 PM
MN
hemidup Offline
hemidup  Offline
MN
Curt
Ah hum, I believe your engine has 6.200" Eagle Feather weight rod's with Honda rod journals and your heads have Rev valve's. I'd have to look up your build sheet cause that was a long time ago.
Jerry Williams.
