Another what will it run post #618815
02/20/10 05:08 PM
02/20/10 05:08 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Ok everyone thanks for looking, I have a .60 over,13.5 to 1 340 in my car now. I am putting a X block 422 CI short block back in.I am keeping all the parts that were on my stock stroke engine and putting them on the new short block. The cam is a soild roller .650 lift, the heads are fully ported Eddies The intake is a M1 with a new Biggs 950 hp. The headders are inch and seven eights stepped TTIs. I don't know what the compression on the new engine will be but I figure 11.5 to 1. My car ran a best of [Email]11.17@119.95.[/Email] How much do you think it will change with that much more cubic inches?
Re: Another what will it run post [Re: Kindafast] #618816
02/20/10 05:18 PM
02/20/10 05:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
KINDAFAST
how heavy is the car what converter, gears,etc?
Re: Another what will it run post [Re: Quicktree] #618817
02/20/10 05:50 PM
02/20/10 05:50 PM
Seaford, Va
Seaford, Va
3175 lbs without me in it. 8" PTC vert, Ladder bar with coilovers and 4.56 rear gears.
6.50 @105.26
Re: Another what will it run post [Re: Kindafast] #618818
02/20/10 06:17 PM
02/20/10 06:17 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
10.30 @ 128.
Re: Another what will it run post [Re: Kindafast] #618819
02/20/10 07:11 PM
02/20/10 07:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
it should run good, pretty close to dustrbd340W5's combo except for the cam. he runs 10.40s and he will pick up some with his new cam. so I would say somewhere around 10.40s +-
Re: Another what will it run post [Re: Quicktree] #618820
02/20/10 10:12 PM
02/20/10 10:12 PM
virginia
572stealth Offline
572stealth  Offline
virginia
Unfortunatly, that is not fast enough.
Re: Another what will it run post [Re: 572stealth] #618821
02/20/10 11:06 PM
02/20/10 11:06 PM
Seaford, Va
Seaford, Va
Yea ,but old age and trechery are on my side.
6.50 @105.26
Re: Another what will it run post [Re: Kindafast] #618822
02/20/10 11:08 PM
02/20/10 11:08 PM
Seaford, Va
Seaford, Va
I was kind of thinking around the mid to lower 10s myself. So it is right in ball park. Thanks,
6.50 @105.26
