Page 2 of 6 1 2 3 4 5 6
Re: Wire guage [Re: 70duster340] #618642
02/23/10 12:36 AM
02/23/10 12:36 AM
RapidRobert Online content
RapidRobert  Online Content
We're still missing something easy as the ammeter would have to be before the fuse block and before the T and the T is before the fuse box because circuits such as the headlight switch ect which are hot all the time and are not fuse protected by the fuse box, current would be flowing (when they are on) but not thru the ammeter and I know that is not the case. I'm assuming you've checked out the wiring diagrams a www.mymopar.com. How is Painless wanting the ammeter to be placed in relation to their fuse box?
Re: Wire guage [Re: RapidRobert] #618643
02/23/10 12:56 AM
02/23/10 12:56 AM
70duster340 Offline OP
According to Painless, the way they advise the fuse block to be wired, it does away with the ammeter. At least, that is what the tech advised. And yes, I have checked with mymopar.com, and no rallye dash wiring diagram. I have located one, but it's for the Barracuda, which has a different rallye gauge setup.
Right now, I cannot locate any wire that powers the gauges. Getting sort of bleary eyed, so I am most likely missing much here.
Re: Wire guage [Re: 70duster340] #618644
02/23/10 01:08 AM
02/23/10 01:08 AM
Actually, this fuse block has provisions for the radio, horn, wipers, heater/AC, etc. I've already wired all those in. It also has provisions for turn signals, emergency flashers, an electric fan (if equipped), coil, ignition switch, light switch, stop switch, dome light, etc. All have been already wired in. I guess I'm only concerned about 2 things, how the gauges are powered, and how to wire in the stock ammeter.
Re: Wire guage [Re: 70duster340] #618645
02/23/10 01:10 AM
02/23/10 01:10 AM
the gauges would be switched on (hence the term switched 12V) from the ign sw and the ign sw is hot all the time so it would be fed from a T before the fuse block. Sounds like Painless is suggesting that you convert to a voltmeter rather than an OE or aftermarket ammeter. EDIT just saw your post. T into the ign switch (ign1) terminal. This is switched 12V and when you turn the key to "on" the gauges will be powered
Re: Wire guage [Re: RapidRobert] #618646
02/23/10 01:17 AM
02/23/10 01:17 AM
OK, but what wire (color, etc.) that is in the round plug that fits in the rear of the cluster, is the wire that feeds the gauges?
Re: Wire guage [Re: 70duster340] #618647
02/23/10 01:19 AM
02/23/10 01:19 AM
My wiring diagram says it's a dark blue wire, but if I follow that wire, it goes to a plug for the rear wiring, which is for the fuel sender unit. I must have something incorrect here.
Re: Wire guage [Re: 70duster340] #618648
02/23/10 01:23 AM
02/23/10 01:23 AM
that'd be in mymopars' diagrams unless that wire is different on a Ralley dash. I did my 65 dart from there wire by wire using spools & no mas and 65 darts are as bare bones as you can get
Re: Wire guage [Re: RapidRobert] #618649
02/23/10 01:25 AM
02/23/10 01:25 AM
Yes, the wires are a bit different on a rallye cluster. Now you can see why I am having so much difficulty (well, at least it is part of the reason!).
Re: Wire guage [Re: 70duster340] #618650
02/23/10 01:45 AM
02/23/10 01:45 AM
that and w the diagrams being split (& cutoff) I couldn't get it either (it'll take some more time) but I'm thinking black or dark blue w a tracer feeds the printed circuit round connector.
We'll get it tomorrow EDIT I think the black wire is the 12V feed in
Re: Wire guage [Re: RapidRobert] #618651
02/23/10 01:24 PM
02/23/10 01:24 PM
OK, now that I've had some rest, the small black wire feeds the gauges. I have it wired to the ignition switch accessory terminal on the fuse block. Does that seem OK? I would think that the gauges should turn on with the key, correct?
Re: Wire guage [Re: 70duster340] #618652
02/23/10 09:11 PM
02/23/10 09:11 PM
BTT!!!
Re: Wire guage [Re: 70duster340] #618653
02/24/10 11:42 AM
02/24/10 11:42 AM
BTT again!!!
Re: Wire guage [Re: 70duster340] #618654
02/24/10 08:57 PM
02/24/10 08:57 PM
Hey Robert, did you come up with anything? I have been sitting here (still on injury leave), and I believe I have figured it out. I also sent an email to the techs at Painless inquiring about wiring in the ammeter, but I was wondering what your thoughts are on this, since I have already wired in the new fuse block. I was also wondering if I should use the terminal for the gauges, or just leave it as is. The fuse block has a provision for gauges, and it's fused.
Let me know!!!
Re: Wire guage [Re: 70duster340] #618655
02/24/10 09:20 PM
02/24/10 09:20 PM
I came up w the little black wire is the 12V feed in on the circular dash plug in. I know the ammeter has to come before anything so that it will register any flow (in either direction). Post what they say.
Re: Wire guage [Re: RapidRobert] #618656
02/24/10 09:27 PM
02/24/10 09:27 PM
OK, will do. It looks like I may have to call them, since they were supposed to reply within 1 business day. They haven't replied as of yet. Whatever they say, I will post.
Thanks again for all the help!
Re: Wire guage [Re: 70duster340] #618657
02/24/10 09:55 PM
02/24/10 09:55 PM
I'm kind of at a standstill too esp as I dont have enough info on how they are wanting you to do this.
Re: Wire guage [Re: RapidRobert] #618658
02/25/10 09:34 AM
02/25/10 09:34 AM
Well, I'll let ya know as soon as I hear from them.
Re: Wire guage [Re: 70duster340] #618659
02/25/10 02:42 PM
02/25/10 02:42 PM
Just spoke with a tech at Painless. They advise against using the stock ammeter, as it's 40 year old technology. I understand their reasoning, but I was hoping to have all my gauges functioning. They suggested the use of an aftermarket voltmeter. They also advised that there may be some company or individual that converts the ammeters to voltmeters. I'm sure this is expensive, but I would consider this if it wouldn't break the bank.
Anybody have any tips or suggestions?
Re: Wire guage [Re: 70duster340] #618660
02/25/10 03:55 PM
02/25/10 03:55 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Depends on your dash. MA did a recent article on converting a 71-74 B-body rally dash ammeter to voltmeter. I did the same with my dash with a voltmeter from a JY Isuzu Trooper (forgot what year). Looks factory. It's doable on the cheap.
Re: Wire guage [Re: MoparMarq] #618661
02/25/10 07:56 PM
02/25/10 07:56 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just found the thread after read your PM... I'm out of time right now, will check later all the thread further.
