Page 1 of 3 1 2 3
Brand new MP 4" stroker crank out of round... #618573
02/20/10 11:15 AM
02/20/10 11:15 AM
Phoenix, Arizona
HerboldRacing Offline OP
Phoenix, Arizona
Check it out... this is brand new shipped from Summit Racing.
http://www.youtube.com/watch?v=Lye9eoLUQdc
WTH. What should I do? I know summit will take it back but I'd have to pay for shipping back to them. Then who is to say I won't simply get another crank like this again from them?
If I put on all the main caps and bearings the crank spins easily for about 180 degrees and takes 2 hands to spin for the other 180 degrees. When I take the caps off I can see some scuffing on lower bearing #4 and some slight scuffing on lower bearing #3.
Marvin Herbold 1973 Plymouth Duster 340 Drag Car Blog - http://www.HerboldRacing.com Videos - http://www.YouTube.com/mherbold Pictures - http://gallery.herbold-family.com/main.php?g2_itemId=10331
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618574
02/20/10 11:19 AM
02/20/10 11:19 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Summit usually will pick up shipping in something like this.
Re: Brand new MP 4" stroker crank out of round... [Re: ademon] #618575
02/20/10 11:34 AM
02/20/10 11:34 AM
Phoenix, Arizona
Phoenix, Arizona
They will? I'll talk to them and find out. Thanks.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618576
02/20/10 01:33 PM
02/20/10 01:33 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Don't take this the wrong way,...but .0015 is nothing (about 1/3 of a human hair strand thickness), you'd be amazed at the amount of deflectional and elastistical movement that crank will go thru under high RPM loads,....even though your gauge is a cheap chinese dial indicator, it appears "good",....it may also be your method of indicating they may be seeing an error, even a small peice of debri or a nick in a bearing shell backside can cause false indications, cranks are sensitive to static loading, it's their nature inherent to their design,.....to swap/replace that crank, you might get one with even more run-out
Granted we would all like to see "ideal" conditions in our engine builds, zero indications, but that ain't going to happen,....most people like to associate engine building to some form of "black art" that catastropic damage will result from the minutist trace of run-out being indicated,....it's a "micro managment" problem that most incounter
IMHO the crank is good to go.......
What I see based on your dial indication
#1 .0002-.0003
#2 .0003-.0004
#3 .0003
#4 .001-.0015
#5 .0001-.0002
Here's a page from Chrysler's FSM regarding V8 crankshafts
Mike
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618577
02/20/10 01:47 PM
02/20/10 01:47 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'm not sure what the print spec is, but it's probably in book range for a street motor.
Problem is you bought a racing/high performance crank that
(I would think) should be better? But that's just an assumption.
If you decide not to run it and Summit won't take care of you let me know. I'm aquainted with a few Mopar Performance folks who would be interested to know about this situation.
Re: Brand new MP 4" stroker crank out of round... [Re: ZIPPY] #618578
02/20/10 02:16 PM
02/20/10 02:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I could see an issuse if the OP was building a 13,000 RPM Pro Stock motor (not with Summit parts though!),.....at best, I'll guess he's building a 10 1/2 to 11 sec motor that will probally only see 6500 RPM max,....after a few hard passes/ 1 seasons worth that .0015 max runout he's worried about will be nothing compared to the other journals "new runout" value
Mike
Re: Brand new MP 4" stroker crank out of round... [Re: DAYCLONA] #618579
02/20/10 03:01 PM
02/20/10 03:01 PM
Phoenix, Arizona
Phoenix, Arizona
You have a point that the run out appears to be pretty minor. However, it does take 2 hands to turn the crank for about 180 degrees of its revolution (with no rods or pistons) and there is scuffing on the number 4 main bearing when I took it out to inspect it. Any further thoughts on that? Here is a picture of the scuffing...
PS Just to clarify when I made that video there were no bearings on the 2, 3, & 4 mains.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618580
02/20/10 03:20 PM
02/20/10 03:20 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
are you sure the problem with #4 is not a cap or bearing issue.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Brand new MP 4" stroker crank out of round... [Re: dusturbd340W5] #618581
02/20/10 04:16 PM
02/20/10 04:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Marvin,....that "scuff" on the #4 bearing is concentrated right at the parting line only,...possibility of a burred edge deflecting the bearing inward on that corner?...either on the backside of the bearing, or at the caps parting line, IMHO
Also a possibility the bearing is sitting just that much higher in it's saddle, that the crush is too much and distorted/mushroomed the bearing corner, causing a "high" spot, which could introduce the drag you feel rotating the crank in one direction only, as the crank will glide past a high edge, rotating "away" from it, but will wipe/cut in reverse
Mike
Re: Brand new MP 4" stroker crank out of round... [Re: DAYCLONA] #618582
02/20/10 04:57 PM
02/20/10 04:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I hate to say this but using a dial indicator as you are is usually done to check for a bent crank, not an out-of-round journal. To determine if a journal is truly out-of-round you'll have to do at least a six point check with a micrometer. You may have some of both but you won't know unless you check.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618583
02/20/10 05:11 PM
02/20/10 05:11 PM
there for sure is a problem (just dont know where/what it is) that needs to be addressed. EDIT might take off one cap at a time & see if you can pin it down/make sure the #3 thrust bearing faces are aligned/put a dial indicator on #3 journal & check runout (not sure if #3 thrust bearings should be removed for this or not but if so for sure dont nick the journal on the bore or better yet tap the #3 upper bearing half around and out).Holler when you have some news.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618584
02/20/10 06:13 PM
02/20/10 06:13 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Did you have that block align honed??
Re: Brand new MP 4" stroker crank out of round... [Re: 6PakBee] #618585
02/20/10 08:53 PM
02/20/10 08:53 PM
Phoenix, Arizona
Phoenix, Arizona
You are right. I got my terminology mixed up. I am going to mic the main journals either tonight or tomorrow and check for out-of-round journals. I will also check for taper.
Re: Brand new MP 4" stroker crank out of round... [Re: Dodgem] #618586
02/20/10 08:55 PM
02/20/10 08:55 PM
Phoenix, Arizona
Phoenix, Arizona
Yes since the main caps came from a different 340 block I had the mains align bored and honed.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618587
02/20/10 09:15 PM
02/20/10 09:15 PM
I'd suggest taking the bearings out & wiping the backsides clean along w the bores then reinstalling them along w the crank (wiping the main journals clean also), lubing the mains up again of course and making sure the bearing halves are seated correctly especialy #3 & if it still will not turn freely then as said I'd mike the journals and check them for runout installed (in the block or on a fixture (lathe or crank polisher).
Re: Brand new MP 4" stroker crank out of round... [Re: RapidRobert] #618588
02/21/10 10:00 PM
02/21/10 10:00 PM
Phoenix, Arizona
Phoenix, Arizona
Ok here is what I know so far...
1) Main journals on the crank are perfectly round at 2.499" everywhere. I mic'ed the journals all the way around and in many places up and down checking for taper... it's all perfect. They may still be off-center but at least they are round.
2) If I tighten up all the nuts to spec (100 ft*lb) on the studs except for #3 main (the middle one) the crank rotates 360 degrees with just one hand on the snout.
3) If I tighten up the nuts on main #3 even a little bit snug I can immediately notice a tight spot when rotating the crank.
4) Tightening up main #3 to spec (100 ft*lb) makes the tight spot tighter. However, the non-tight spot is still easy to rotate with just one hand on the snout. The tight spot requires 2 hands to rotate the crank.
5) I rotated crank into the tight spot then I put a bit of plastigage (about 1/4") at the top of the crank journal on #3 and put the cap and bearing on and tightened to spec, then removed cap and bearing. Looks like I have less than .001 clearance. Is this too tight?
6) I took only the #3 main cap and bearing off and put a dial gauge on it. Turned the crank - there very little movement of the dial gauge needle (I would say 0.0002 or less)
Ok, educate me. Something wrong with the bearings? I'm trying to understand why it doesn't like it when I torque up the nuts on the #3 mains. I'm almost to the point where I think I am going to take this to the machine shop that align bored and honed my mains and have them look at it...
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618589
02/21/10 10:03 PM
02/21/10 10:03 PM
Kissimmee Fl.
Kissimmee Fl.
#3 is the thrust bearing are you setting the thrust part of the bearing before you torque the nuts?
Re: Brand new MP 4" stroker crank out of round... [Re: dusturbd340W5] #618590
02/21/10 10:09 PM
02/21/10 10:09 PM
Phoenix, Arizona
Phoenix, Arizona
Right, #3 is the thrust bearing...
What do you mean by "setting the thrust part of the bearing"? I'm not doing anything special to #3...
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618591
02/21/10 10:11 PM
02/21/10 10:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Just my . At the tight spot, use a piece of plastigauge that is the full width of the journal on all five mains. Torque them down and check the clearances. Then rotate the crank 180 degrees and repeat for all five mains. The two times in my life that I've line honed a set of main bearing bores, a plastigauge check prior to the machine work showed a steady increase (or decrease) in the bearing clearances from one end of the block to the other.
Re: Brand new MP 4" stroker crank out of round... [Re: HerboldRacing] #618592
02/21/10 10:17 PM
02/21/10 10:17 PM
Kissimmee Fl.
Kissimmee Fl.
To set the thrust you should take a large screw driver pry the crank forward between 1 of the other main cap and counter weight and use a brass hammer and lightly hit the rear flange while holding the screw driver and then torque the cap before letting go.
Page 1 of 3 1 2 3
