boosted cams,post yours.
#618467
02/20/10 03:37 AM
02/20/10 03:37 AM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
what have you used and on what,roots,procharger,turbo?
i have used 3 cams with my roots 8-71. comp cam solid part# 23-000-S grind# CRB3 6059/6061 S 113.0 lift int.541/exh.559 113 LSA dur at .015 289/297 dur at .050 252/260 valve timing at .050 open int 13BTDC close59 ABDC open exh 63BBDC close 17 ATDC 113 intake center
the current 1 i have in is comp cam roller grind# CRB3 4131B /4046B R 112.0 lash at .020 lift int .646/631exh dur at .020 291/306 valve timing at .050 open int 21 BTDC close 59 ABDC open exh 69 BBDC close 19 ATDC installed at 109 CL spec dur at .050 260/269 112 LSA
Re: boosted cams,post yours.
[Re: headhunter]
#618470
02/20/10 01:39 PM
02/20/10 01:39 PM
blownzoom440
ELYRIA,OH
havent gotten that far yet lol
well you should be looking so you are not in a hurry when the time comes! 1 of the reasons for this post is to bring info to those in need.now if people will post there info instead of thinking thay have some top secret cam thay should get over it. we are here to help each other not worry about what others might think of them.rant over.what ya got?
[Re: blownzoom440]
#618473
02/20/10 05:21 PM
02/20/10 05:21 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've been wondering about turbo cams for a while. Mine makes good power despite being an itty bitty .486" custom grind. I don't have the specs in my head but I have the cam card at home.
I know the turbo Buick guys as well as the Supras were running really strong numbers on stock cams.
[Re: feets]
#618474
02/20/10 05:40 PM
02/20/10 05:40 PM
blownzoom440
ELYRIA,OH
i had talked to my brother about the motorcycle cams used on a turbo hayabusa making 600HP from 1400cc's and he said the cams are a lot like the N/A cams.
[Re: blownzoom440]
#618475
02/20/10 08:20 PM
02/20/10 08:20 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I will likely use the one in my engine 112 lsa intake 230 @ 50 - 525 lift exhaust 236 @ 50 - 539 lift
It is a small hydralic roller
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: Defbob]
#618478
02/20/10 09:46 PM
02/20/10 09:46 PM
Posts: 3,336 Summit, NJ
whiplash
Summit, NJ
hughes 3038 cam on a 114 lsa
- 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
- 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
- NEW BEST ET - 12.40@110mph...
Post deleted by Defbob
[Re: whiplash]
#618479
02/20/10 10:17 PM
02/20/10 10:17 PM
#618480
02/21/10 03:08 AM
02/21/10 03:08 AM
Posts: 200 AB
Efidart
AB
Still have this cam sitting on the shelf from my old roots setup solid flat tappet.
252 262 @ .050 .560 .580 lift 114 lsa I believe.
Turbo setup has a solid roller I'd have to look at the cam card again for exact specs but its about 274-286 @ .050 .680 .680 116.5 LSA. Idles like a .509 mopar cam.
TT Predator headed 572 7 Second Street Car. Fastest Mopar Drag Week 2015 Fastest Mopar & Dodge Drag Week 2017 Pro Street Power Adder Champion Drag Week 2017
[Re: Efidart]
#618481
02/21/10 08:47 AM
02/21/10 08:47 AM
Posts: 2,175 Duloc
The Shadow
Duloc
The cam that was in my sdce bb was a roller 609/631 247/260@.050 115 lsa Anybody looking for a procharger cam?
[Re: DaytonaTurbo]
#618483
02/22/10 12:19 AM
02/22/10 12:19 AM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
The wide LSA is to keep overlap and reversion to a minimum, you want to use the boost to push the piston down, and not let the exhaust back into the chamber or intake charge. When LSA is narrower, overlap is larger. (all other numbers being equal)
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: blownzoom440]
#618484
02/22/10 10:45 PM
02/22/10 10:45 PM
feets
Senior Management
Senior Management
Irving, TX
Here's my monster cam specs. Think you can hang with this baby? This is rocket science right here! intake/exhaust .006 duration 284/280 lift .474/.483 .050 intake open 6 btdc close 50 abdc .050 exhaust open 48 bbdc close 4 atdc duration at .050 236/232 lobe lift .3160/.3220 separation 112 You can see there's only 10 degrees of overlap. That's as tight as we could get it without going to a custom blank. Keep in mind that this cam was ground 10 years ago. Comp wasn't doing a lot of turbo cams since turbos V8s weren't very common. Much has changed since this thing was built. I'm sure people know far more about turbo cams now than they did then. However, this thing makes decent power. You can't argue with that.
