Oil viscosity and horsepower loss #618233
02/19/10 07:25 PM
02/19/10 07:25 PM
Missouri
galen Offline OP
galen  Offline OP
Missouri
Been using 15-40 Brad Penn, Just put the engine back togetherand went with .001 additional clearance on my rod bearings. Was just going to pre-lube and look things over with my valley plate off. Only oil I had on the shelf was 20-50. Stuck my high powered rockwell air drill on the pump and when it built pressure it will about twist the drill out of my hands. I have to wonder what the actual load on the pump shaft is with the 20-50 compared to the 15-40 or even 10-30. I am going to see if the engine will hold good pressure with the 10-30 hot.
Re: Oil viscosity and horsepower loss [Re: galen] #618234
02/19/10 08:05 PM
02/19/10 08:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hard to say when it`s hot but I agree w/you on the hand drill cold oil...........it`s syrup thick and I run eighter 5-30 or 10-30 in my car that`s heavily street driven w/bearing clearances bet. .023-.027 w/out issues.
Re: Oil viscosity and horsepower loss [Re: galen] #618235
02/20/10 12:18 AM
02/20/10 12:18 AM
When I first stated dyno testing motors I would see a HP loss with cold oil using 30 WT Valvoline HD oil, motor would make 460 HP 5900 RPM with 130 F oil temps, no other changes the motor would make 475 HP at 5900 RPM with the oil at 180 F with no other changes I now use 5W 20WT or 5W 30 WT Valvoline HD oil and see no HP increase or loss between 100 F and 200 F I do see a pressure drop from 45 Lbs at 1100 RPM with 100 F oil temps and at 180 F oil temp I see 25 lbs at 1100 RPM The car is a lot more constsitent at the track with the thin multi weight also
Re: Oil viscosity and horsepower loss [Re: Cab_Burge] #618236
02/20/10 11:24 AM
02/20/10 11:24 AM
NC
440Jim Offline
440Jim  Offline
NC
I find this graph informative when talking viscosity. Especially temperature variation and multi-grade vs straight weight oils.
Look at the example of the straight weight oil at room temp!
Re: Oil viscosity and horsepower loss [Re: 440Jim] #618237
02/20/10 12:05 PM
02/20/10 12:05 PM
AndyF Offline
AndyF  Offline
Yep, at 20 below an engine with 40 wt oil probably won't even turn over. Need a block heater to get the oil warm or else that baby is stuck.
Re: Oil viscosity and horsepower loss [Re: AndyF] #618238
02/20/10 02:16 PM
02/20/10 02:16 PM
SoCal
Brian Hafliger Offline
SoCal
In engines using hyd cams, I use 20w50. Hyd. system seems to prefer this (makes more HP).
In solid roller or FT stuff I use 10w30 and make all dyno pulls in the 160° range.
Brian Hafliger
Re: Oil viscosity and horsepower loss [Re: Brian Hafliger] #618239
02/20/10 11:27 PM
02/20/10 11:27 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
IMO 20W50 is the best compromise for drag racing. I've seen 2 different dyno tests that saw less than 3 HP difference between 20W50 and 0 weight specialty oil. These test were in the 160 degree range.
