any one know if 225 70 15 will fit the front of chally #617905
02/19/10 02:10 PM
02/19/10 02:10 PM
ME
79machocharger Offline OP
ME
Just wondering if 225 70 15's will fit fine on the front of a 70 challenger, any one running that size on the front yours? I think I'll go with 235 75 15's on the back. If any one has any pics with show what 225 70 15's on the front I'd love to see them, thanks.
Re: any one know if 225 70 15 will fit the front of chally [Re: 79machocharger] #617906
02/19/10 08:52 PM
02/19/10 08:52 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
that sounds pretty large. If you have the torsion bars cranked way up, it will help some with clearance, but I would bet you rub when you turn. Wheel off set will make a difference also. I left 14s on the front of mine just because of previous rub problems with 15s on the front of other mopars that I've owened.
DRIVE EM, DONT HIDE EM.
Re: any one know if 225 70 15 will fit the front of chally [Re: 79machocharger] #617907
02/19/10 09:44 PM
02/19/10 09:44 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
When I was buying tires for my 70 Challenger I tried a 225-70-15 (on a 15x7 rally) and it didn't fit. It brushed the fender at the front of the tire when the wheel was turned. I ended up going with a 60 series tire.
Re: any one know if 225 70 15 will fit the front of chally [Re: 79machocharger] #617908
02/20/10 01:26 AM
02/20/10 01:26 AM
louisiana
69charger2002 Offline
louisiana
yeah 225/70 will most likely rub.. 235/75/15 on back? that is scary skinny! hope ou have a 318 in it because you sure won't be getting traction. not to mention it won't fill out the rear wheel wells at all!
Re: any one know if 225 70 15 will fit the front of chally [Re: 69charger2002] #617909
02/20/10 11:37 AM
02/20/10 11:37 AM
Middle River, MD
Mapandjlp Offline
Mapandjlp  Offline
Middle River, MD
Mine '70 Challenger has 215/70/15 on 15 x 7 rallyes on the front. No rub at all. Some might say my torsion bars are a little tight but it has a good stance...
Re: any one know if 225 70 15 will fit the front of chally [Re: Mapandjlp] #617910
02/20/10 07:25 PM
02/20/10 07:25 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
I have 225 70 15 on the front of my Challenger. They do not rub, but there is not much room between it and the front of the fender.
