Re: 392 Hemi in a 69 Bee?
[Re: Dougsmopars]
#617875
02/21/10 04:47 PM
02/21/10 04:47 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
It's his car. I'm not gonna knock anybody for putting Mopar power in a mopar car.
Nor am I, and I only said that because I've heard others do it and the fact is, it will happen. Also as I said, it may or may not bother him accordingly, just a little advance warning that's all. I don't think you and I are as different as you might be assuming concerning our taste in cars, I like original numbers matching cars, but I ALSO like modified rods as well, I'm not stuck in a single niche. I agree with you concerning the 392 build costs, and yes, a like equipped 426 would likely cost more, however, to get a 392 to weigh within 50lbs of a SB Chevy isn't cheap, that was the jist of my posting what I did, this guy is talking about putting a basically stock 392 into a 69 Bee, and as such that combo will be boat anchor HP/Weight ratio.
My current project ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: DaytonaTurbo]
#617879
02/22/10 12:12 PM
02/22/10 12:12 PM
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Then I think the early hemi heads didn't flow even close to the 426 hemi heads.
I'm with you on most of your post but you'll get some arguement on the above comment. Early Hemi heads are EXCELLENT flowing heads. In stock form most agree the 354's are the best followed closely by the 392's.
[Re: ScottSmith_Harms]
#617880
02/22/10 12:15 PM
02/22/10 12:15 PM
DaytonaTurbo
Manitoba, Canada
Anyone know for sure what they flow compared to 426 heads? I had just heard the early hemi heads aren't as good but never seen some actual flow test #'s to back it up.
[Re: DusterKrazy]
#617883
02/22/10 12:38 PM
02/22/10 12:38 PM
Posts: 4,794 Holland MI Ottawa
2boltmain
Holland MI Ottawa
If you can afford it do it!! The engine is cool, has history and is still rare. I worked with a man that had a 69 chevelle with a 409 dual quad engine. Cool cool cool.
Keep old mopars alive.
[Re: 2boltmain]
#617884
02/22/10 06:04 PM
02/22/10 06:04 PM
Posts: 88 Kansas City, MO
coledavis01
Kansas City, MO
The original thought for considering the whole deal was money...the 383 is apart needing a bit of machine work & I figured if I mothballed the factory motor for the time being and built up the 392 (given that it could be had for cheap) I'd have about the same amount of money involved, but as a lot of you have said, this would most likely not be the case and with the weight disadvantage of the hemi it wouldn't be adding much beyond the visual effect of having the hemi under the hood. I really like that Plymouth wagon! Cole ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
[Re: coledavis01]
#617885
02/22/10 06:19 PM
02/22/10 06:19 PM
Posts: 583 San Antonio, TX
CurYellowBird
San Antonio, TX
IMO there is nothing wrong with a 392 hemi. It's better than having a 331 baby hemi. Buy it and moth ball it. Keep the numbers drivetrain in the superbee. I bought a 440 to put in my 71' roadrunner that has the numbers 383. I decided now to just build the car as she came and leave it alone. Sure, everyone is saying "put a 440 in it!" but now how often do you see mopars running around with the original 383? Superbees and roadrunners are awesome cars if left alone. I don't agree with stroking the 383 if it's the numbers matching engine. That's asking to screw it up. Find another 383 if your going to do that. If your superbee is complete and nothing big is missing, then leave it alone. You'll save stupid money by reusing or rebuilding any parts you can. Just bought my complete interior from legendary because I didn't have to spend all that extra money on a second motor. Up to you what you do. Wanna be unique, go with the 392. Wanna keep it original, go with the 383. Pat ![](/ubbthreads/images/graemlins/2241092-prplchrgr.gif)
Project War Bird:
1971 Plymouth Roadrunner
383 4 speed with air conditioning
GY3 Curious yellow
All original
