'73 Charger Sway Bar #617793
02/19/10 12:45 PM
02/19/10 12:45 PM
Orange Park, FL
MRHWS Offline OP
MRHWS  Offline OP
Orange Park, FL
What years rear sway bar will fit a '73 Charger? Is there a diameter difference between a 340, 400 or 440 equipped car? I never see the rear bar for sale, only the front. Are there any aftermarket bars being produced?
1973 Charger SE 1974 Charger Rallye 440 Aztec 2008 Charger SRT8
Re: '73 Charger Sway Bar [Re: MRHWS] #617794
02/19/10 08:08 PM
02/19/10 08:08 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
The bars themselves will swap out between 71-74...The differences I've seen is there's a "dip" in the center to clear the bigger rears {8 3/4,dana,9 1/4} but some have shown the straight bar as original for the 8 3/4...What you do need for sure is the 73-up axle mounting bracket for the isolated rear set-up...You can get them off a road runner,charger, cordoba, magnum etc...Here's a pic of the typical B body bar...
Re: '73 Charger Sway Bar [Re: screamindriver] #617795
02/19/10 08:22 PM
02/19/10 08:22 PM
Harrisburg, Pa.
Harrisburg, Pa.
Here's a pic of the isolated rear bar bracket in place between the spring and rear housing...The rear b body bars are still in the boneyards around here for the isolated set-ups...Mabe there's some in your area also..There's aftermarket bars out there but not like the original set-up...And not cheaper than originals either..
Re: '73 Charger Sway Bar [Re: screamindriver] #617796
02/26/10 03:27 PM
02/26/10 03:27 PM
Jacksonville Fl
Y
yellowdartdave Offline
Y
Jacksonville Fl
MRHWS,
FYI,
There is a Cordoba at the U-Pull-It on Normandy that has a rear bar on it.
If you don't get it, I will.
It is near the back of the Mopar section.
