How do I remove an ignition switch from a 70 E body? #617579
02/19/10 12:06 AM
02/19/10 12:06 AM
Woodbridge,CA
NAS Backyard Offline OP
Woodbridge,CA
Working on bringing my 70 Challenger back to life, it ran 10 years ago but the ignition switch is all jacked up. How do I get it out? Looks like it was replaced before. Thanks
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: How do I remove an ignition switch from a 70 E body? [Re: NAS Backyard] #617580
02/19/10 12:53 AM
02/19/10 12:53 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617581
02/19/10 12:53 AM
02/19/10 12:53 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617582
02/19/10 12:54 AM
02/19/10 12:54 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617583
02/19/10 12:54 AM
02/19/10 12:54 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617584
02/19/10 12:55 AM
02/19/10 12:55 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
.....Click on the word "attachment" for enlargement
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617585
02/19/10 09:41 AM
02/19/10 09:41 AM
Woodbridge,CA
Woodbridge,CA
Thanks alot! I'll print these out. I guess I should repair the damaged piece too. Looks like I'll be making a shopping list for Spring Fling. Thanks again.
Re: How do I remove an ignition switch from a 70 E body? [Re: NAS Backyard] #617586
02/19/10 10:58 AM
02/19/10 10:58 AM
IMGTX Offline
IMGTX  Offline
Excellent Pics Mike.
I will add that the tools in Figures #8 & #9 aren't needed.
For Figure #8 You can usually wiggle the top housing off of the shaft. In some cases place two screwdrivers between the upper & middle housings to gently pry the upper housing off the shaft after removing the snap ring.
For figure #9 use a drift and hammer to tap the pin out.
Those factory tools are great but pretty much unavailable.
The good news is that upper housing is not a really hard piece to get. Mopars from Trucks to A bodies used virtually the same columns. The differences are the shafts and the tubular lower shaft housings in most cases. You can probably get the upper housing easy. Now in 70 the middle housing that holds ignition switch uses a pin to hold the lock cylinder but later years used a spring clip. That may be able to be replaced with any year but the big problem is the lower housings. In 70 they used an ingnition interlock on floor shift cars and if that part is damaged you need a 70 only part. Looks like yours is fine. The damage around the lock cylinder looks like it will be covered by the new lock cylinder so your good.
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617587
02/19/10 11:07 AM
02/19/10 11:07 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
First thing to do is buy a factory manual.If you are going to work on that its worth its weight in gold.Rocky
Chrysler Firepower
Re: How do I remove an ignition switch from a 70 E body? [Re: therocks] #617588
02/19/10 06:31 PM
02/19/10 06:31 PM
N.E. Ohio
mike69rr Offline
mike69rr  Offline
N.E. Ohio
Re: How do I remove an ignition switch from a 70 E body? [Re: mike69rr] #617589
03/13/10 06:47 PM
03/13/10 06:47 PM
Woodbridge,CA
Woodbridge,CA
I printed out the instructions and finally got the switch for 27.00. Do I need any specialized pullers or can I use a steering lock plate remover thats used on GM cars to press shaft out of bearing? Looks kind of intimidating but I will take pics as I go.Thanks again DAYCLONA for the great info.
Re: How do I remove an ignition switch from a 70 E body? [Re: NAS Backyard] #617590
03/13/10 10:57 PM
03/13/10 10:57 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Tim,...you'll need a puller with slightly longer than usual bolts to remove the ribbed canister from the column to gain access to the column internals, after that a good assortment of general hand tools, a little swearing and cussing should get the jod done, looks daunting at first, but is fairly straight forward, just organize/layout the parts neatly inorder as they came out, incase you forget the order in which to return them
Mike
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617591
03/14/10 12:03 PM
03/14/10 12:03 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Mike
The cheap steering wheel puller from Harbor Freight will go inside the crush can and pull it out. Before I bought that, I was using long lengths of all thread to get in there. It also has a lock plate tool.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42031
Staying organized as Mike suggested is the only way to go with any repair. Take it from someone who learned it later in life, lol.
Craig
Re: How do I remove an ignition switch from a 70 E body? [Re: denfireguy] #617592
03/14/10 12:51 PM
03/14/10 12:51 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
One other tip, when you are laying out all the parts in order and have all the tools spread out, make sure to leave a path out of the car, because you WILL need another tool!!!
You will be suprized at how many tools this takes!
Re: How do I remove an ignition switch from a 70 E body? [Re: DAYCLONA] #617593
07/04/14 11:57 PM
07/04/14 11:57 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Says to clamp assembly in a vice. Am I correct in assuming that entire column need not be removed to repair/replace switch.
As noted in another thread I am unable to turn my key to the Acc position, nor will my steering wheel lock when in key removal lock position. A posting to that thread suggests that my lock which had been installed by a previous owner, was likely done so incorrectly. The previous owner has said to me that perhaps,,,but not certain,,,that some parts may not been put back in.
Service manual gives no info on whether column or shaft must be removed or not.
Re: How do I remove an ignition switch from a 70 E body? [Re: Sxrxrnr] #617594
07/05/14 12:30 AM
07/05/14 12:30 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You are correct in your assumption...You don't have to remove the column or the shaft to replace the switch but you'll need to deal with the lock plate in some manner..Take a look and see which parts were discarded then decide...
