Too much compression for pump gas? #617545
02/18/10 11:57 PM
02/18/10 11:57 PM
Spokane,WA
Genuinejed Offline OP
Spokane,WA
I'm swapping a set of Pro Comp victor knock offs on my 426 Wedge and I'm wondering if I'm going to have to run into problems with detonation. The motor is .070 over and has kb237s .025 in the hole. The heads are 72ccs and the cam is a Voodoo 60304. The compression calculator I used said 12.2 to one! Anyone have ideas or experience with a combo like this on pump? With the old 452s I never had any problems, but I'm a little concerned I might hurt the pistons.
1968 Plymouth road runner 1968 Dodge Coronet 500 64 D200 Good, Fast, Cheap. Pick Two.
Re: Too much compression for pump gas? [Re: Genuinejed] #617546
02/19/10 12:29 AM
02/19/10 12:29 AM
What altitude is it where you drive it? What compression was the motor with the 452 heads and is it the same cam still?
Re: Too much compression for pump gas? [Re: Genuinejed] #617547
02/19/10 01:05 AM
02/19/10 01:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m not sure how totally accurate it is but cranking comp. seems to be what a lot of people gauge PART of it on and my 12.11 motor runs/drives fine on 91 pump junk. When I race I mix 110 leaded and hammer down.
Re: Too much compression for pump gas? [Re: Genuinejed] #617548
02/19/10 01:21 AM
02/19/10 01:21 AM
Utah
topbrent Offline
topbrent  Offline
Utah
I'm swapping a set of Pro Comp victor knock offs on my 426 Wedge and I'm wondering if I'm going to have to run into problems with detonation. The motor is .070 over and has kb237s .025 in the hole. The heads are 72ccs and the cam is a Voodoo 60304. The compression calculator I used said 12.2 to one! ...
Using the calculator on the KB website, and assuming that you will use a standard .039 head gasket, I come up with 10.727 compression ratio.
http://www.kb-silvolite.com/kb_car/performance.php?action=details&P_id=30
http://www.kb-silvolite.com/calc.php?action=comp
Re: Too much compression for pump gas? [Re: topbrent] #617549
02/19/10 08:45 AM
02/19/10 08:45 AM
Spokane,WA
Spokane,WA
Thanks for the link. When I enter the 72cc chamber KBs website says 11.5 to 1, the more accurate calculator says 12 to 1. I'm at 2120 feet above sea level. With the old heads and the same cam it was 10.47 to 1 using the calculator. I'm hoping the cam will lower the dynamic compression. I'll probably add some race gas when I go to the strip, I'm just hoping I don't have to run it all the time. Thanks for the help!
Re: Too much compression for pump gas? [Re: Genuinejed] #617550
02/19/10 12:48 PM
02/19/10 12:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Run a cranking comp. test and tell us what you`ve got...........
Re: Too much compression for pump gas? [Re: Genuinejed] #617551
02/19/10 12:59 PM
02/19/10 12:59 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
The online CR (static) calculator I like best is the one on the Diamond Pistons web site (diamondracing.net).
I don't know how big the cam is you're talking about using, but if you have 11.5 CR and anything smaller than about 275 @ .050", it'll probably ping on pump gas. I'm expecting to be at (or over?) the limit for 93 octane w/ around 11.0 and something in the 265-268 @ .050" range.
Re: Too much compression for pump gas? [Re: BradH] #617552
02/19/10 02:29 PM
02/19/10 02:29 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
67wedge runs a 268/272 at 11.4 to 1 on pump gas and i was 11.12 and ran pump 93 with a 248/254 and made my passes on pump 93 ......the higher the Intake closing ABDC cam timing event helps with this...
I checked my cranking pressure on one of those calcs(engine not done yet) and its saying 180psi and im gonna be right at 11 to 1 with a 269/269 bullet roller .... I was torn between the 11.5 /11.0 deal also...... I also had my heads milled back to the correct 75 cc rating after the cnc porting was done...
Mopar Performance
Re: Too much compression for pump gas? [Re: moparniac] #617553
02/19/10 02:55 PM
02/19/10 02:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 12.11 comp. heap cranks at around 170 w/275-280 dur.@.050 and runs fine on 91 but, I ALWAYS mix in 110 when racing........do I need it? Not sure but gas is cheap and pistons/rings arent.
Re: Too much compression for pump gas? [Re: Genuinejed] #617554
02/19/10 03:05 PM
02/19/10 03:05 PM
Camp Point, IL
gofish Offline
gofish  Offline
Camp Point, IL
What is the quench area now? If the heads are a closed chamber type, that will be the problem.
Danny
Re: Too much compression for pump gas? [Re: Thumperdart] #617555
02/20/10 12:26 PM
02/20/10 12:26 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
My 12.11 comp. heap cranks at around 170 w/275-280 [Email]dur.@.050[/Email] and runs fine on 91 but, I ALWAYS mix in 110 when racing........do I need it? Not sure but gas is cheap and pistons/rings arent.
dom whats your dynamic compression ratio
Mopar Performance
Re: Too much compression for pump gas? [Re: moparniac] #617556
02/20/10 12:41 PM
02/20/10 12:41 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I have a question . My 557"KB/RBRE Hemi is a 11.5 : 1 motor (static) and won`t run with 91 oct pump gas . Can the dynamic comp be higher than the static comp ????
Chryco
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Too much compression for pump gas? [Re: moparniac] #617557
02/20/10 01:54 PM
02/20/10 01:54 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t know how to figure that out......have always gauged it on cranking.
Re: Too much compression for pump gas? [Re: Thumperdart] #617558
02/20/10 02:15 PM
02/20/10 02:15 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
http://www.wallaceracing.com/dynamic-cr.php
Mopar Performance
Re: Too much compression for pump gas? [Re: moparniac] #617559
02/20/10 02:58 PM
02/20/10 02:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Unless I`m doing something wrong,it says my dynamic comp. is 7.59........damn that seems low.
Re: Too much compression for pump gas? [Re: chryco] #617560
02/20/10 05:50 PM
02/20/10 05:50 PM
UK
602heavy Offline
602heavy  Offline
UK
Chryco
Static will always be higher than dynamic , unless of course the intake valve shut @ BDC.
Re: Too much compression for pump gas? [Re: Thumperdart] #617561
02/20/10 05:58 PM
02/20/10 05:58 PM
UK
602heavy Offline
602heavy  Offline
UK
I lost a good 3/10ths down track using 116 race gas , the motor is 9.5:1 & i was using the 116 for nitrous , ran the motor NA on the 116.
If the motor does'nt warrant high octane fuel it will always slow down , you can add advance to the motor to compensate but the more advance you give the motor the more it will slow the piston down.
Re: Too much compression for pump gas? [Re: 602heavy] #617562
02/20/10 07:18 PM
02/20/10 07:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Are you saying your static or dynamic was 9.5:1?
Re: Too much compression for pump gas? [Re: 602heavy] #617563
02/20/10 07:54 PM
02/20/10 07:54 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Chryco
That`s what I thought. How would you get something from nothing ?
Re: Too much compression for pump gas? [Re: Thumperdart] #617564
02/20/10 08:54 PM
02/20/10 08:54 PM
UK
602heavy Offline
602heavy  Offline
UK
Static was 9.5:1 , i gave this as an example , obviously the motor does'nt need race gas @ that CR , but some guys use race gas for belt & braces...........higher octane requires the spark to be fired off earlier , as the mixture expands it trys to push the piston down the hole , the less spark lead to get optimum leverage ATDC the better , spark lead on my motor was around 40* , since raised the CR for this reason.
