how much for rings/rod,main bearings for426 hemi?
#616680
02/18/10 02:19 AM
02/18/10 02:19 AM
Posts: 8,858 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
im gonne replace the bearings and rings(all spossed to be standard but have not checked yet so how much? brand? and where to buy from ? is there any differnace between a hemi and a 383 set of rings?
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: how much for rings/rod,main bearings for426 hemi?
[Re: toplescuda]
#616681
02/18/10 07:41 AM
02/18/10 07:41 AM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
Rings will probably set you back about 130-150. Rings go by bore size, file fit, ring groove width and type of material (moly, stainless, etc) and now there are Napier 2nd groove rings, standard and low tension oil rings (don't use the low tension oil rings for a street, street/strip motor)
A good rod bearing (H series) like 527HD or 527HND is around 200 (they usually only come as an "N" narrow bearing to clear the fillet, and "D" with dowel holes which ups the cost). There is also a 527HNDX which gives you .001" more clearance. A normal P bearing would be a little less.
The standard MS896P full groove bearings I have found is pretty pricey (around $180). The other choices are the Federal Mogul 119M (3/4 groove) or the MS2233HG which has a slight groove at each end. The 119M and 2233HG are probably around the same price.
