Plum Crazy paint? best?
#616541
02/17/10 11:43 PM
02/17/10 11:43 PM
Posts: 2,094 New Mexico
JMCFAN
New Mexico
Wondering about best all around match etc for Plum Crazy paint? brand etc...?? Car in currety in light bare primer and want to start right..
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Plum Crazy paint? best?
[Re: JMCFAN]
#616542
02/18/10 02:04 AM
02/18/10 02:04 AM
Posts: 903 Oregon
rtplumcrazy1
my friend who wons a body shop and restores Mopars-believes PPG to be the best match. I have seen many cars that were painted by him using PPG FC-7 plum crazy/in violet, that matched the original color great/including my own 70 Challenger.
Put a big block 4 speed Scat Pack Dodge in your garage.
[Re: rtplumcrazy1]
#616543
02/18/10 10:55 AM
02/18/10 10:55 AM
Posts: 8,526 Tenn.
jrwoodjoe
Tenn.
FC7 was among the colors I had been strongly considering for my project. From my research, PPG as mentioned above had the look I was going for and and seemed to be the best match. KEEP IN MIND, if the person mixing it doesn't do things just right then you're not going to get what you want anyway.
Joe
65 Barracuda 70 Challenger
[Re: jrwoodjoe]
#616544
02/18/10 11:33 AM
02/18/10 11:33 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
PPG is the best, and as already mentioned, the color primer, how it is applied, etc. can all create various shades of the color. If I was trying to be dead on for the color I would use ruddy red primer like the factory and shoot single stage. However that would really be difficult with the mettallic so with using bc/cc I would apply 4 coats of base and three clear.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
[Re: JMCFAN]
#616545
02/18/10 11:22 PM
02/18/10 11:22 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
We used PPG Deltron Base Coat (DBC) on the '71 'Cuda in the link. DBC will give a much better color match than you will get with PPG Global Base Coat. Steve www.clarkclassic.com
[Re: RUNCHARGER]
#616547
02/18/10 11:45 PM
02/18/10 11:45 PM
Posts: 15,995 RI Deep in the rust belt
chargervert
The Dupont shades of Plum Crazy seem to run a little light,the PPG is more accurate.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: RUNCHARGER]
#616548
02/18/10 11:55 PM
02/18/10 11:55 PM
Posts: 17 ohio
ta340
ohio
Factory primer was grey with FC7. I remember because there was a problem with the FC7 peeling when new and there was greay underneath the carnage.
Sheldon
Like this
[Re: chargervert]
#616549
02/18/10 11:55 PM
02/18/10 11:55 PM
Posts: 1,385 Ohio
rck850
Ohio
[Re: rck850]
#616550
02/19/10 12:53 AM
02/19/10 12:53 AM
Posts: 1,647 IL
71383beep
IL
Yep PPG on mine too... Cloudy Day... Sunny Day...
'73 GK6 Challenger Rallye - 340 4-Speed
[Re: MOPARMIKE69]
#616552
02/19/10 08:58 AM
02/19/10 08:58 AM
Posts: 2,304 WI
RestoRick
WI
Sheldon
Like this
Looks like grey and Ruddy red primer.
The red oxide was the factory primer-surfacer applied directly over treated bare metal. This primer was machine wet sanded. Following that, directly under the topcoat color, was a light gray primer-sealer.
Your earlier comment about using "ruddy red" primer to affect the final color is inaccurate.
Rick
[Re: MOPARMIKE69]
#616553
02/19/10 09:00 AM
02/19/10 09:00 AM
chargervert
I bought a 70 Charger R/T FC7 car from the original owner,and he said when the car was about a year and a half old,the paint started peeling off in sheets,he said he had to use the windshield wipers to clear the glass of the peeling paint while he was driving. Chrysler repainted the whole car the color of his choice,except Plum Crazy. Original Plum Crazy cars seem to have red oxide primer first,then grey primer,then Plum Crazy.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: MOPARMIKE69]
#616555
02/19/10 11:35 AM
02/19/10 11:35 AM
Posts: 2,304 WI
RestoRick
WI
