17x8 Magnum Wheels #616393
02/17/10 10:33 PM
02/17/10 10:33 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
Anyone ever seen these on a mopar before? I know they're offered by vintique and specialty wheel but they only show the regular sized magnum, not the actual 17x8 wheel. Any input appreciated.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616394
02/17/10 11:59 PM
02/17/10 11:59 PM
San Antonio, TX
San Antonio, TX
No one has ever seen or used these wheels? I know one guy showed a chally with AR's version of a billet magnum. Looked good but I had another guy mentioned that the 17x8 magnum wheel produced now is simply a 14 inch magnum center in a big rim.
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616395
02/18/10 12:03 AM
02/18/10 12:03 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I buy alot of steel outers, from one of the larger companies making them. They do make a 17" outer with a big drop to use a standard 15" center. IMO they look kinda bad..
They have also started making a 17" one with a larger ID to use a special sized center so it does not have that huge lip. I have not tried any yet, because they don't sell a center to go with it. It could be the ones you mentioned are using these outers and the other company is getting center stamped out by someone else who instead of by the same company as the outers.
(and that other company stamping the centers probably won't sell them to anyone else...or there would be more out there)
Personally I wouldn't bother with a 17" steel wheel...just too heavy. I just would (and do) go with two piece billet stuff.
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616396
02/18/10 12:09 AM
02/18/10 12:09 AM
Nebraska
71cudajoe Offline
71cudajoe  Offline
Nebraska
I've only seen them a couple times. I'm thinking of buying a set for my Cuda. Here's a picture of a 71 Cuda with these wheels. I hope this helps.
Re: 17x8 Magnum Wheels [Re: 71cudajoe] #616397
02/18/10 12:11 AM
02/18/10 12:11 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Guy must be too lazy to peel the sticker off his tire before trailering it there
Re: 17x8 Magnum Wheels [Re: OzHemi] #616398
02/18/10 12:23 AM
02/18/10 12:23 AM
San Antonio, TX
San Antonio, TX
I want to keep the car with the stock look but I think the 14x6 magnums are just too small. My dad's buddy gave me a set of 285/75/SR15 BFGoodrich white letter tires that are nice and fat so I'll probably go with the 15x7 magnums.
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616399
02/18/10 12:24 AM
02/18/10 12:24 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
IMO a 7" wheel is too narrow for that size tire. (and that is going to be a quite tall tire keep in mind)
Re: 17x8 Magnum Wheels [Re: OzHemi] #616400
02/18/10 12:29 AM
02/18/10 12:29 AM
San Antonio, TX
San Antonio, TX
you thinking 15x8 front and rear maybe? Or 15x8 rear and 15x7 front?
Thanks cudajoe,
that does really help since my RR's factory color is that same color lol. Those actually don't look bad. My only kinda lean is that I have to fat tires to put in the back. Thing with 71' RR's is that they really don't look that bad with larger wheels and lo pro tires.
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616401
02/18/10 12:32 AM
02/18/10 12:32 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I don't know the specs on that tire, but they probably recommended them to go on a 10" wheel. (most things over a 275 are..) but an 8" at a bare minumum and see how they wear.
7" up front is an easy one..
Again, check and see how those tires even fit...it's a big tire. In a 15", a 275/60 would be the most common size I've seen/used.
Re: 17x8 Magnum Wheels [Re: OzHemi] #616402
02/18/10 12:36 AM
02/18/10 12:36 AM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You can get taller 17" tires too of course if you want to go with the larger diameter wheel.
Re: 17x8 Magnum Wheels [Re: OzHemi] #616403
02/18/10 12:36 AM
02/18/10 12:36 AM
San Antonio, TX
San Antonio, TX
That's probably the hardest part is figuring out the right size which I'm sure specialty or vintique could tell me. I know the tires should fit fine with the fat wheel tubs in 71' b bodies.
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616404
02/18/10 08:40 PM
02/18/10 08:40 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
American Racing has the AR 500, which is a Magnum look-alike in aluminum. Available in 15 inch and 17 inch. At this time I think they are special order custom offset only. They have catalog numbers for standard offsets, but nobody seems to stock them.
Check ebay for the deals.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: 17x8 Magnum Wheels [Re: 471Magnum] #616405
02/18/10 08:50 PM
02/18/10 08:50 PM
San Antonio, TX
San Antonio, TX
471magnum,
Do you go over to the roadrunnernest forum at all?
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616406
02/18/10 09:14 PM
02/18/10 09:14 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
maybe....
-Jim
Re: 17x8 Magnum Wheels [Re: 471Magnum] #616407
02/18/10 09:50 PM
02/18/10 09:50 PM
San Antonio, TX
San Antonio, TX
This is pats71'. Thanks again for the pics btw
Re: 17x8 Magnum Wheels [Re: CurYellowBird] #616408
02/25/10 08:38 AM
02/25/10 08:38 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Here is a pic of the 16-17 inch Magnum 500 wheel. This is a steel wheel , not billet. Yes it is heavy , but holds true to the orginal style of the wheel. The center part of the wheel has been increased to fit the 16 inch and 17 inch bands that are avaliable. These wheels come in 16 x 7 , 16 x 8 and 17 x 8 from Specailty Wheels.
I am there one of their midwest vendors.
The Wheel Guy
Re: 17x8 Magnum Wheels [Re: duster2] #616409
02/25/10 08:43 AM
02/25/10 08:43 AM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
Here is a pic I took of one of the 16 x 7 Magnums I have in the trailer ( Have four in stock ) They can be see in person at the Indy Cylinder Head show in Indianapolis , March 6-7
The Wheel Guy
Re: 17x8 Magnum Wheels [Re: duster2] #616410
03/01/10 01:44 PM
03/01/10 01:44 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Sorry...I have been out of commission for 5 days now with a bad virus. I have these on my 69 Charger....17 x 8 all around....255/55 on the rear and 235/55 on the front. I got them from Wheel Vintques (I think) about 4 years ago. I love them. More pics on my site in my sig
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
