indy -1s on a 440
#614881
02/16/10 07:33 PM
02/16/10 07:33 PM
Posts: 461 Hinterland SE Qld Aust
SG duster
my current short block set up is a std stroke eagle crank, eagle H beams & .040 12.5 pop ups, with indy heads being 75ccs it should net around 12.8 to 1, Im wondering if unported indy -1s will be too big for this level of engine,
track duty only no street use in a 1/2 chassi'ed duster around 3000lb tops, transbraked glide with 4000 or 5000 converter (I have both) 31 or 32" tyre with 4.56s
Iv got some parts together to later on screw a source 543 together and only want to buy one set of heads.
heres an old picture of it
Re: indy -1s on a 440
[Re: RonP]
#614886
02/16/10 09:32 PM
02/16/10 09:32 PM
SG duster
I do already have the blue 1.6 rockers & shafts with hughes hold downs, a set of manley -1 head bolts, indy push rods, 1009 gaskets, iv got a flat tappet here 256/260 on a 108,I have a 950hp series holley etc
I dont have a valley or intake to suit yet but thats no probs
I guess now its just a forgone conclution to go a set of -1s, foot brake mid low 10s is right where & want it to be.
[Re: SG duster]
#614887
02/16/10 09:45 PM
02/16/10 09:45 PM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
My brother put a very similar engine together for a friend. Pretty much same shortblock. 263/267 Roller on a 110, 1000 cfm square flange, ootb -1's J&W's loosest rated 8" converter for a glide, rated at 6400, went 6100 with this combo!! 2700 lb. full chassis 68 Barracuda 4.56 gear, 9.26-145 best with only 1.35 60ft. Engine worked great from 5800 to 7000, but with the right converter and gear it ran hard.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#614888
02/16/10 10:08 PM
02/16/10 10:08 PM
SG duster
my 3000lb is based on the current iron headed 440 & 727, steel hood & doors with glass and regulators etc.
forgot to mention I also have a source girdle & indy alloy caps,
[Re: SG duster]
#614890
02/16/10 10:25 PM
02/16/10 10:25 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I think it will run good, I have a few diff engine sizes under my belt with the 440-1 heads, from OOTB to full cnc porting. I think it will be in your favor to mill the heads .038-.040 or so and get the head volume down to 70cc or so. This is very conman, and leaves plenty for future milling. Get the compression up on that engine means a ton. A friend (HillBilly Conquest) ran a similar engine one a 493 with flat tops, maybe 12.5:1, and then run the same engine same cam ect but now a stock stroke 440 with a set of Blob dome pistons which yielded 14:1 or so. That engine was a animal. it was several tenths better than the 493. The cam he ran was the old Comp .690 roller, single plan Indy intake and old 9375 dominator. Hope this helps. I would be careful how I cam'd the engine. A solid roller with dur in the high 260-low 270's range, and as much lift as I could possibly get. If the heads are Box stock, you will want to at least pull the valves and do some bowl work. There is a ton to be gained right there spending only minutes under each valve. The engine with the roller mentioned before will want to shift at 7K or a tad higher. A 5000 flash converter would be minimal.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: SG duster]
#614892
02/16/10 10:46 PM
02/16/10 10:46 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I'd re-think the glide. Think the combo would be better suited to a 3 speed. I had the -1's on my car and the best et was 10.49 at 130 With my 915's it's capable of 10 teens with 6.40's in the 1/8th Too much slow moving air in those -1's for me. What about the SR's and then take them to Max size later
[Re: roadhazard]
#614893
02/16/10 10:58 PM
02/16/10 10:58 PM
SG duster
with s/r's they still have the dog leg around the push rod pinch. later on Im moving towards a 540 & s/r's would be too small.
And why re-think the girdle?
[Re: SG duster]
#614895
02/16/10 11:07 PM
02/16/10 11:07 PM
roadhazard
Akron, Ohio U.S.A.
No the powerglide. The GLIDE has what gear set in it? A 2.08 first? The torqueflight has a 2.45 and puts you up in the RPM a lot quicker and that will help with the oversize port volume. My motor is a pig with the -1's and a 3 speed. With the 915's it rev's like a small block
