Re: 23 spline vs 18 spline 833
[Re: 440beep]
#61485
05/22/08 03:44 PM
05/22/08 03:44 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I'm running a 602Hp Hemi in my Road Runner in front of a 23 spline box, however I'm not dumping the clutch at 6000RPM or power shifting it and I'm running on street tires.
There have been some who have taken out a 23 spline unit (usually it's 3rd gear that gets it), but who knows what they were doing that led to the problem.
If you don't beat up on it too much, it should be fine.
[Re: RUNCHARGER]
#61487
05/22/08 10:05 PM
05/22/08 10:05 PM
Posts: 1,611 Pataskala, Ohio
GTX70sixpack
Pataskala, Ohio
I've had a 23 spline in my GTX for the last twenty years. I couldn't find a clutch disc for the 18 spline back then so I used the tranny from a 69 383 Bee. It has held up fine. I finally put the 18 spline in last month.
65 Belvedere II Station Wagon 69 Coronet R/T convertible 70 GTX 70'cuda 99 Dodge Diesel dually 4X4
[Re: fourgearsavoy]
#61494
05/24/08 09:49 AM
05/24/08 09:49 AM
Posts: 45 Queens, NYC
Racer413
Queens, NYC
Here is a third gear that was behind a mild 440 with bias ply 14"tires
I think there was something wrong with that trans to begin with
[Re: Racer413]
#61495
05/24/08 10:04 AM
05/24/08 10:04 AM
Posts: 2,836 Detroit boy in Saugerties, NY
BrianShaughnessy
I know 2 friends that blew up 23 splines in the last year behind a 440 and a 500.
Do not beat on it with sticky tires.
Black Betty: '69 Charger RT: 440 6 pack, TKO600 5 speed, 3.73 Dana. Sinnamon: '69 Charger RT: 440, 727, 4.30 8.75. High School Sweetheart. El Grande: '98 Grand Cherokee 5.9 Limited.
