Re: I need traction. What will fit?
[Re: OA5599]
#614536
02/16/10 03:01 PM
02/16/10 03:01 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
My brothers 69 Cuda has Cal tracs and split mono leafs in the stock location and the body and wheel tubs are completely stock. We are running a 15X8 inch Weld Wheel with a 275/60-15 Mickey Thompson Street Drag Radial and it hooks great and goes 1.40 on a good track and 1.45 on a so so track. I cant remember the offset on the wheel however. I think a 4 1/2 offset. I will find out for you. It fits perfect and never rubs. We actually used to have SuperStock Springs and they never conflicted with the tires either.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: maximum entropy]
#614539
02/16/10 09:11 PM
02/16/10 09:11 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
the largest tire possible will just fit- any larger and you could conceivably have interference issues.
I have heard that. I had the 7/8" offset kit in an early A body with 265 / 60 15's and had room for a sandwich on each side of the tire. 4 1/2 back space.
[Re: Cab_Burge]
#614542
02/16/10 11:15 PM
02/16/10 11:15 PM
Posts: 834 Beavercreek, Ohio
OA5599
Beavercreek, Ohio
The rallyes in Summit are 15x8 with a 4.625 backspace. Will those fit along with a 275/50-15 on my 69 Cuda? Kind of looking for a straight yes or no before I swipe the card...
Do you have long wheel studs now? If so you could always add a 1/8 spacer to help center the wheels if they're to close to the inside If no long wheel studs maybe now is the time to add them How much are the steel wheels and how much do they weigh?Lighter is always better Easier to accelerate and to stop
Rallye costs $108 per wheel and ship tomorrow. Custom 5x4 15" steel wheels are 125 with no paint. I have rallyes on it now, so they would match the front. Weight is not listed.
[Re: OA5599]
#614544
02/18/10 03:47 AM
02/18/10 03:47 AM
Posts: 316 Coolville, Ohio
Lew
Coolville, Ohio
Thanks. I would really like to stay away from Centerline or anything that looks too aftermarket unless I absolutely have to. If I know for sure what backspacing I need to make the whole setup work, then I can go from there...as long as it fits.
Lets see if Sloan gets back with you on his brothers set up, looks like his car sets higher in the rear than yours.
