I need traction. What will fit? #614534
02/16/10 12:32 PM
02/16/10 12:32 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
My dad and I have a 69 Cuda 340 with stock suspension. Ran low 13s with factory stall and street tires, but it had to be tuned to bog so it wouldn't blow the tires away on the launch. With the new 10" converter I just bought, it has no chance of hooking. I have a small bolt pattern, so I'm just going to buy some small bolt rallyes from summit unless i can find a better deal. So...how big of a wheel/tire can I fit on the rear of my stock Cuda. I would really like a 275/50 on a 15x8. I've ran the numbers and the height is perfect as it's the same as I have now...just not sure if the width will work. Will that fit on my stock Cuda? If not, what is the max wheel/tire that WILL fit? These will be for the track only, not cruising. So I will not be cornering.
Re: I need traction. What will fit? [Re: OA5599] #614535
02/16/10 02:29 PM
02/16/10 02:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
Centerline makes the Auto Drag rims (have to order them and wait for them to make them) in 8.5 wide with a both the 3 1/8 and 4.7/8 offsets in the 4 inch bolt pattern
Re: I need traction. What will fit? [Re: OA5599] #614536
02/16/10 03:01 PM
02/16/10 03:01 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
My brothers 69 Cuda has Cal tracs and split mono leafs in the stock location and the body and wheel tubs are completely stock. We are running a 15X8 inch Weld Wheel with a 275/60-15 Mickey Thompson Street Drag Radial and it hooks great and goes 1.40 on a good track and 1.45 on a so so track. I cant remember the offset on the wheel however. I think a 4 1/2 offset. I will find out for you. It fits perfect and never rubs. We actually used to have SuperStock Springs and they never conflicted with the tires either.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: I need traction. What will fit? [Re: PUNK] #614537
02/16/10 05:04 PM
02/16/10 05:04 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Thanks. I would really like to stay away from Centerline or anything that looks too aftermarket unless I absolutely have to. If I know for sure what backspacing I need to make the whole setup work, then I can go from there...as long as it fits.
Re: I need traction. What will fit? [Re: OA5599] #614538
02/16/10 05:26 PM
02/16/10 05:26 PM
organ
maximum entropy Offline
organ
the largest tire possible will just fit- any larger and you could conceivably have interference issues.
Re: I need traction. What will fit? [Re: maximum entropy] #614539
02/16/10 09:11 PM
02/16/10 09:11 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
I have heard that.
I had the 7/8" offset kit in an early A body with 265 / 60 15's and had room for a sandwich on each side of the tire.
4 1/2 back space.
Re: I need traction. What will fit? [Re: tubtar] #614540
02/16/10 10:44 PM
02/16/10 10:44 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
The rallyes in Summit are 15x8 with a 4.625 backspace. Will those fit along with a 275/50-15 on my 69 Cuda? Kind of looking for a straight yes or no before I swipe the card...
Re: I need traction. What will fit? [Re: OA5599] #614541
02/16/10 11:10 PM
02/16/10 11:10 PM
Do you have long wheel studs now? If so you could always add a 1/8 spacer to help center the wheels if they're to close to the inside If no long wheel studs maybe now is the time to add them How much are the steel wheels and how much do they weigh?Lighter is always better Easier to accelerate and to stop
Re: I need traction. What will fit? [Re: Cab_Burge] #614542
02/16/10 11:15 PM
02/16/10 11:15 PM
Beavercreek, Ohio
OA5599 Offline OP
OA5599  Offline OP
Beavercreek, Ohio
Rallye costs $108 per wheel and ship tomorrow. Custom 5x4 15" steel wheels are 125 with no paint. I have rallyes on it now, so they would match the front. Weight is not listed.
Re: I need traction. What will fit? [Re: OA5599] #614543
02/17/10 08:56 AM
02/17/10 08:56 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Never having had that combination will prevent a lot of us from giving a definitive yes or no.
I will commit to " it works on paper '
You may need a 1/4" spacer , but they should stuff in there O.K.
Re: I need traction. What will fit? [Re: OA5599] #614544
02/18/10 03:47 AM
02/18/10 03:47 AM
Coolville, Ohio
Lew Offline
Lew  Offline
Coolville, Ohio
Lets see if Sloan gets back with you on his brothers set up, looks like his car sets higher in the rear than yours.
Re: I need traction. What will fit? [Re: OA5599] #614545
02/18/10 04:17 AM
02/18/10 04:17 AM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I'm putting a set of SLT alloy wheels and mickey thompson et streets on my 69 Dart with small bolt pattern also changing to 1/2 wheel studs to get away from the smaller 7/16 studs. wheels are here should be a nice fit
