Hot starter? #614328
02/15/10 11:11 PM
02/15/10 11:11 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I have been having hot starting issues like after my car has been run for a while then stopping to get gas.
I was thinking my starting probelms were stemming from vapor lock but now I am wondering if the heat is also affecting the starter because the last time it happened I was able to get a jump from the vehicle behind me and my car fired right up.
how much does the heat affect the starter?
I got some starter heat wrap to try out & maybe it will help
anybody else have thoughts into this problem?
thanks
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hot starter? [Re: RylisPro] #614329
02/15/10 11:49 PM
02/15/10 11:49 PM
Colo Springs, Co
dragaddict Offline
super street
dragaddict  Offline
super street
Colo Springs, Co
I have had more problems with a ground cable doing wierd things. Heat causes more resistance. Easy enough to try a couple of ground straps. Easy jump starts lead me to think this.
Re: Hot starter? [Re: RylisPro] #614330
02/16/10 03:39 AM
02/16/10 03:39 AM
Some suggestions.I'd clean EVERY cable end/connection starting at the batt positive post to the starter relay to the starter, starter to block, block to neg cable, neg cable cleaned at neg post. The complete large cable circuit. borrow a known good battery & try it, sub in another starter, check your charging voltage and might add an ign cutoff & start cranking the starter then switch on the ign which solved this problem on our stock car. Starters are strange (electrical) beasts in that they draw more current the slower they turn which drains the battery further which makes the starter turn even slower and this happens (in effect) smoothly in a matter of seconds. When the eng is hot pull the plugs and check the turning torque on the 1&1/4" crank bolt.EDIT meant to say cranking voltage
Re: Hot starter? [Re: RapidRobert] #614331
02/16/10 08:08 AM
02/16/10 08:08 AM
Rome, Ga
sbhpcb Offline
sbhpcb  Offline
Rome, Ga
I have a issue not related to heat. On my 72 340 cuda, The starter will act as if the battery is dead. You can always jump the stater relay and it will fire right up. I have changed the relay. and even did a Mc giver trick of adding 2 more 30 amp relays in parralle so that all 3 relays add power to the starter. It still does the same thing, open the hood and jump the relay with a screwdriver and it fires right off???
Re: Hot starter? [Re: RylisPro] #614332
02/16/10 11:38 AM
02/16/10 11:38 AM
Missouri
MY340 Offline
MY340  Offline
Missouri
Need more info.
What type of starter do you have? full size or mini?
Do you have headers?
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: Hot starter? [Re: MY340] #614333
02/16/10 11:59 AM
02/16/10 11:59 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
full size starter and headers
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Hot starter? [Re: RylisPro] #614334
02/16/10 12:35 PM
02/16/10 12:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I had a duster with trunk mounted batt, that did the hard crank thing when hot. Used to pump gas pedal a bit to flood the thing so it would crank. Ended up using the stock newer nippo starter and never looked back.
Re: Hot starter? [Re: dragaddict] #614335
02/16/10 01:46 PM
02/16/10 01:46 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I think I may have fixed it!
I got a braided ground strap and bolted that to the engine mount and frame
then I ran the car until it got up to temp and my electric fans kicked in.
shut it off and cleaned up my tools (same amount of time it would take to get some gas) and started it again.
fired right up!
maybe all I needed was another ground?
I'll test it on the road and see what happens
thanks guys
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
