Removing Power Window Motors from Regulators
#614313
02/15/10 10:59 PM
02/15/10 10:59 PM
Posts: 366 San Gabriel, CA 91775
rexus31
I've got a '65 Chrysler 300 'vert with power windows. The car was sitting for over 20 years and the regulators/motors are all gummed up. The regulator/motor assemblies are out of the car. I know there is a proper orientation the regulators need to be in (not certain what it is though) to safely remove the motors but I am not able to engage the motors to get the regulators in position. Any recommendations? I have a feeling if I try and remove the motors as they are not I may lose a finger or something. Any help would be appreciated.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Removing Power Window Motors from Regulators
[Re: rexus31]
#614314
02/15/10 11:31 PM
02/15/10 11:31 PM
Posts: 67 Florida
T-Man
You just need to clamp into a vice to keep the spring from releasing. No big deal don't use to much pressure.
Now be sure you get the motor back on or you lose your vice until u get it back on.
67 plymouth satellite
72 plymouth roadrunner
[Re: rexus31]
#614315
02/15/10 11:37 PM
02/15/10 11:37 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
Yes, be very careful they can be dangerous. I had to take them apart on my 69 Coronet one time and wasn't too safe in my technique but didn't hurt myself. I'd say the vice is the best way to do it.
Darren
[Re: 1_WILD_RT]
#614317
02/15/10 11:50 PM
02/15/10 11:50 PM
rexus31
As mentioned you can clamp them in a vise.. But chances are you'll want to clean & lube the regulator while the motor is removed so the better approach is to attach longer leads to the wires from the motor & to run the regulator to the end of travel in the direction that releases spring tension.. Then clamp it & unbolt the motor.. After that you can release the clamp while holding the gear & mounting plate & after unclamping you can release the spring tension with your hands... It won't have much tension left if you release most of it before removing the motor...
There's problem #2. The motors/regulators are so caked the motors cannot move. Also, would the regulator in the full up or down position release the spring tension?
[Re: Ludington1]
#614320
02/16/10 08:37 AM
02/16/10 08:37 AM
Posts: 21,081 Niles , Ohio
therocks
Niles , Ohio
Those springs are nasty.I know.Broke 2 fingers and sliced my knuckles wide open when one popped on me.I had done probally 50 before with no problems.Just took one to get me.Rocky
Chrysler Firepower
[Re: therocks]
#614321
02/17/10 01:05 AM
02/17/10 01:05 AM
Posts: 2,679 Maple Ridge, BC, Canada
Barnabas_Kriss
I had that happen to me too, didn't break my finger, but did get a nasty cut. The scar is still visible after 12 years.
