Painting Crackle Paint #614289
02/15/10 10:37 PM
02/15/10 10:37 PM
North Riverside IL & Lowell IN
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I have no luck getting crackle paint to crackle, every time I spray it the paint ends up smooth as silk and I'm following directions to the letter.
Anyone have good results with this stuff?
Re: Painting Crackle Paint [Re: GTXKen] #614290
02/15/10 11:01 PM
02/15/10 11:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I've always had good results. Needs to be in a warm space and the coats have to be quite heavy.
Did you shake the can well?
Re: Painting Crackle Paint [Re: Stanton] #614291
02/15/10 11:19 PM
02/15/10 11:19 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Shook the crap out of it and painted it in my basement at like 65 degrees
Re: Painting Crackle Paint [Re: GTXKen] #614292
02/15/10 11:36 PM
02/15/10 11:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
You need to stick a heat gun or hairdryer on it after each coat.
Re: Painting Crackle Paint [Re: Neil] #614293
02/15/10 11:40 PM
02/15/10 11:40 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I can try that
Re: Painting Crackle Paint [Re: GTXKen] #614294
02/15/10 11:46 PM
02/15/10 11:46 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I did mine on a 90+ day in the sun and it still didn't come to life until I busted out the hair dryer. I put on two decent coats and warmed it up after each one.
FYI even though the top surface may feel hard it can still be plenty soft underneath. In those temps I'd plan on letting it sit for a few days before handling it too much.
Re: Painting Crackle Paint [Re: Neil] #614295
02/15/10 11:53 PM
02/15/10 11:53 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
I just put it in the oven at 200 and its starting to crackle
Re: Painting Crackle Paint [Re: GTXKen] #614296
02/16/10 10:19 AM
02/16/10 10:19 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Thanks for the replys last night! It was a duh moment, I put painted part (air cleaner lid) in the oven for like 10 minutes at 200 and it turned out great.
Re: Painting Crackle Paint [Re: GTXKen] #614297
02/16/10 11:23 AM
02/16/10 11:23 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Yep, heat is the cure (pun intended!)
A safer method than an oven is the halogen shop lights.
Re: Painting Crackle Paint [Re: Neil] #614298
02/16/10 11:25 AM
02/16/10 11:25 AM
jamestown, ny
71scamp440 Offline
Hinged
71scamp440  Offline
Hinged
jamestown, ny
heat gun is the way to go. just stay back a few inches and do not stop moving the gun for too long in one spot or imperfections will show up.
71 scamp big block with 915 heads 727 trans
Re: Painting Crackle Paint [Re: 71scamp440] #614299
02/16/10 11:39 AM
02/16/10 11:39 AM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I used a BBQ as my family would not let me put some valve covers in the oven. Still turned out nice!
Re: Painting Crackle Paint [Re: Devil] #614300
02/16/10 11:42 AM
02/16/10 11:42 AM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Plus you can get that nice hickory flavor!
Re: Painting Crackle Paint [Re: GTXKen] #614301
02/16/10 12:50 PM
02/16/10 12:50 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I painted a set of valve covers on a cool day last fall. I could tell that the paint was not going to cure properly so I looked around to find a spot that had the most direct sunlight. I got a ladder out and put them up on the roof of the house. I would go up occasioanlly and re-position them so all areas of the valve covers would cure evenly. It worked!
Stan
Re: Painting Crackle Paint [Re: GTXKen] #614302
02/16/10 01:32 PM
02/16/10 01:32 PM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
I got my air cleaner powder-coated in wrinkle-black and it came out great.
Re: Painting Crackle Paint [Re: GTXKen] #614303
02/16/10 01:44 PM
02/16/10 01:44 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Rustoleum Black Textured S/G. No curing:
Re: Painting Crackle Paint [Re: Commando1] #614304
02/16/10 02:11 PM
02/16/10 02:11 PM
GTXKen Offline OP
super gas
GTXKen  Offline OP
super gas
Really? I was using summit stuff, my buddy used eastwood and had the same problem I did
Re: Painting Crackle Paint [Re: GTXKen] #614305
02/16/10 06:56 PM
02/16/10 06:56 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I used Harley Wrinkle Paint, worked great and looks stock.
I think I have pictures around here somewhere of the set I did.
