Re: Strange or AFCO front coil over shocks?
[Re: joshking440]
#614093
02/15/10 05:59 PM
02/15/10 05:59 PM
Posts: 951 Temperance, MI
prochargedhemi
Temperance, MI
Call Mike at MR2Performance for a set of Santhoffs!!!
Agreed 100% I would rate afco and strange very close to the same (the afcos are a bit nicer but the stranges have a lil better price) and have to say that santhoffs are dang near the best out
[Re: dizuster]
#614096
02/15/10 11:48 PM
02/15/10 11:48 PM
Posts: 1,163 Newark, OH
Hunted Duck
Newark, OH
Yeah I'm doing the conversion myself. The cage is already tied into the shock tower, so I just need to make a few tabs for the upper mount...
Here's a pic of the frame, shouldn't be too hard to make the upper mount.
As I understand it, I need to cut the lower control arm stop bracket off of the frame right?
Looks like it would hit the shock if I didn't...
I didn't have to cut the bracket off when I did mine. I just put a didn't stopper on.
[Re: dizuster]
#614100
02/16/10 10:29 PM
02/16/10 10:29 PM
Hunted Duck
Newark, OH
Ok, I should be fine then. Does your still use the stock lower control arm stopper?
Thanks for sharing the info.
Scott
Yep. I just used some fender shims to shim it up alittle. No problem. Have you drilled and tapped your pivot arms yet?
