67 belvedere hood #614032
02/15/10 02:21 PM
02/15/10 02:21 PM
Maryland
rickracer Offline OP
Maryland
I am ready to mount a fiberglass Hemi hood scoop to the steel hood off of my 67 Belvedere. Does anyone know the spacing between the back of the hood and the scoop?
Re: 67 belvedere hood [Re: rickracer] #614033
02/15/10 02:27 PM
02/15/10 02:27 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
Depending on your carb location ...as far FORWARD as possible .. to get the best "air".
Re: 67 belvedere hood [Re: rickracer] #614034
02/15/10 02:30 PM
02/15/10 02:30 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
depending on size...my Superstock hood was about 4.5 inches from the back of the hood to back of scoop base...and centered
Re: 67 belvedere hood [Re: terzmo] #614035
02/15/10 02:44 PM
02/15/10 02:44 PM
Maryland
Maryland
I want the scoop to be in the correct factory position if possible.
Re: 67 belvedere hood [Re: rickracer] #614036
02/15/10 02:57 PM
02/15/10 02:57 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
Hi,
when I put mine on I got a Glasstek one cause it has the reverse lip on the bottom like the steel factory one so you can use the slid on clips and bolts from the bottom up, if you look at the bracing on the bottom of the hood at the rear the factory has flat recesses in the braces, I used those for putting the rear holes in the hood and the scoop ended up being about a 1/2in from the rear of the hood. Also later when I put a small brace in the scoop opening in the center, when I drilled the hole there was and extra stiffner in my hood right in that spot, so I must have the scoop in the correct spot. I can take some close up pic's of the under side if you need them.
Russ
Re: 67 belvedere hood [Re: rickracer] #614037
02/15/10 03:00 PM
02/15/10 03:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
If you are using a factory style 67 Hemi Scoop the correct location for the rear edge of the scoop is nearly flush with the back edge of the hood. I say "nearly" because it varied a bit from one car to the next, most cars I've seen were 1/8" to a 1/4" tops from the rear edge.
Re: 67 belvedere hood [Re: ScottSmith_Harms] #614038
02/15/10 03:02 PM
02/15/10 03:02 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
65 scoops were different in shape but the application was similar, this is a rare look at an original, never removed, still in original paint (yes it's a factory A990 65 Hemi car in Petty Blue). The sealant around the base is body caulking/seam sealer and it's original as well.
Re: 67 belvedere hood [Re: ScottSmith_Harms] #614039
02/15/10 03:12 PM
02/15/10 03:12 PM
New Jersey, USA
bosshemi66 Offline
bosshemi66  Offline
New Jersey, USA
I have an original 67 RO23 scoop and its mounted about an 1/8 from the edge
Re: 67 belvedere hood [Re: ScottSmith_Harms] #614040
02/15/10 03:12 PM
02/15/10 03:12 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I looked at mine in the back and it looks like the white car Scott posted. mine is just under a 1/4in. I thought it was more , I screwed up. Scott would know , he's the man!
Russ
Re: 67 belvedere hood [Re: old_racer] #614041
02/15/10 03:18 PM
02/15/10 03:18 PM
Maryland
Maryland
Thanks everyone - that helps alot.
