Re: AAR rear springs [Re: moparclown] #61316
05/29/08 07:35 PM
05/29/08 07:35 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Hey Moparclown - thanks, don't know if this helps you out any, but in my opinion the 043 are not original for a '70 340 Chally. Here's why. Plymouth had a soft spot, it seems, for the 340 'Cuda. Giving unto them, the above standard items, among many others. The small block was quite a performer in an E Body once given those goodies. 0-60mph times were basically equal to a Hemi then faded hard in the second half of the 1320.
I owned a '70 340 'Cuda and sold it later, but I did keep the rear axle (3.55 Sure grip) and leaf springs. The 024/034's that I inquired of. I learned most everyhing I know from Mopar mags written by those who know what I don't. Among the things I learned was the S15 XHD suspension given to 340 'Cuda's. Since 70440+6BBl has confirmed what I thought - that they are 'Hemi' springs, I would only surmise they were original to the car, just as I had learned in the early 90's.
It may be that when I take the original springs from my 383's rear axle next weekend I will find it has the 043 springs too. Again - 044 is the code on the BCS.
Did Dodge have a soft spot for the 340 cars too, I think so, even if Plymouth gave the 340 as a no cost option and Dodge charged extra! Hope this helps any, don't take my word alone, maybe someone can tell us both for sure. Have a blast this summer with that Chally of yours Moparclown.
Re: AAR rear springs [Re: moparclown] #61317
05/29/08 08:47 PM
05/29/08 08:47 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
340 Challengers too Doug.
Re: AAR rear springs [Re: Alaskan_TA] #61318
05/29/08 09:00 PM
05/29/08 09:00 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Dodge had a soft spot, but I guess it wasn't for their 340 cars. If Barry is right, and I'm not at all questioning this, then the S15 susp with 024/034 springs were optional on Challys and not standard. So that 043 springs were standard fare for 340 Challengers, not 340 'Cudas.
There is only the question of a non-R/T 340 Challenger V8 vs a real 340 R/T and to which spring was standard, maybe both came standard with 043 and 024/034 was optional on both?
With a little more investigation Moparclown...you can find out for sure - unless the answer was just given by our good man Barry W. Thanks guys.
Re: AAR rear springs [Re: ebodyseast] #61319
05/29/08 09:26 PM
05/29/08 09:26 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
OK, just dug up a bunch of buildsheets that I have collected over the years from parts cars, etc...
IIRC- Plymouth only included the 15" wheel standard on 340 'Cudas for the early part of the 1970 model year, then the 14" became standard. The Hemi suspension was mandatory with axle package cars, but not with 3.23 rears...
I have a sheet for BS23H0B321856 with a SPD of 429 and it clearly lists rear springs as 043/043. Shows 3.23 with D91 sure grip. Car has the W23 Road Wheel option. Also lists- S13 suspension...
Re: AAR rear springs [Re: 70440+6bbl] #61320
05/29/08 09:43 PM
05/29/08 09:43 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
'70 Barracuda BH23C0B123929 013/013
'70 Barracuda BH23C0B377778 013/013
'70 Challenger JH23G0B191253 014/014
'70 Barracuda BH27G0B249777 044/044 (misprint maybe???)
'70 Challenger RT/SE JS29V0B147156 024/034 S15
'70 Challenger JH23L0B193551 043/043
'70 'Cuda BS23N0B209441 043/043 S15
'70 Barracuda BH23N0B211062 024/034 S15
'70 'Cuda BS23N0B216454 024/034 S15
'70 'Cuda BS23U0B367830 024/034 S15 (Very cool as the fender tag and both sheets list the engine code as E87 and engine code as 122 which is 440+6bbl built to heater specs)
'70 'Cuda BS23R0B146459 024/034 S15
Re: AAR rear springs [Re: 70440+6bbl] #61321
05/29/08 09:56 PM
05/29/08 09:56 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Now we're talkin' - it pays to keep diggin' for the truth. The info just provided is much needed and goes beyong just the AAR springs and their part numbers. The AAR springs are 4 1/2 leaves, but special, they add a height increase to rear for clearance for the side exit exhaust. Thanks for taking the time to upload all those BCS's 70440+6bbl, cool brother.
The Challenger with the 383 2bbl, L code, it has 043 springs listed. Maybe I am missing something here, but they may be a standard vs HD standard compared to my 044 code. Will be good to know if the 044 code is actually standard HD springs for conv.'s.
Re: AAR rear springs [Re: ebodyseast] #61322
05/29/08 10:05 PM
05/29/08 10:05 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
No problem Is your 044 spring car a ragtop???
Re: AAR rear springs [Re: ebodyseast] #61323
05/29/08 10:12 PM
05/29/08 10:12 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The 340 was not available in a R/T in 1970.
Re: AAR rear springs [Re: 70440+6bbl] #61324
05/29/08 10:12 PM
05/29/08 10:12 PM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Yes a conv, I made sure to post my VIN: BH27NOB earlier in the thread to help clarify this issue of what is original to what cars, especially those missing a BCS where this info is recorded. Barry mentioned 'Cudas and R/T's for the 043 springs pictured and since my 383 4bbl is closely related to a 'Cuda in small ways I wanted to include for our discussion.
I think I mentioned the parts catalog listing a standard spring (043?), for which there is a HD counterpart (044?), and then there are the HD springs with their Extreme duty counterparts. Would like to help Moparclown get the right parts the first time around. What is your opinion for his 340 Challenger. Thanks Barry for setting me straight on the 340 going into only Challenger V8's.
Re: AAR rear springs [Re: ebodyseast] #61325
05/29/08 11:08 PM
05/29/08 11:08 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I know convertibles had heavier rate rear springs because of the additional weight & I thought A/C had something to do with rear springs also but I guess not. EDIT - I added a few, thought I had some convertibles (somewhere?).
Axle packages "upped" the springs on 340/383 cars.
Went thru a bunch of b'cast sheets:
JH23C - 013/013
JH23C - S13 - 042/042
JH23G - 014/014
JH27G - 015/015
JH23H - S13 - 043/043
JH27H - S13 - 044/044
JH23J - S13 - 048/048
JH23L - S13 - 043/043
JH23N - S15 - 034/024
JS23N - S13 - 043/043
JS23N - S15 - 034/024
JS27N - S13 - 044/044
JS29N - S13 - 043/043
JS23U - S15 - 034/024
JS23U - A36 - S15 - 034/024
JS23V - S15 - 034/024
JS23V - A32 - S15 - 034/024
JS23V - A33 - S15 - 034/024
JS23V - A34 - S15 - 034/024
JS29V - A36 - S15 - 034/024
JS23R - S15 - 034/024
JS23R - A32 - S15 - 034/024
JS23R - A33 - S15 - 034/024
JS23R - A34 - S15 - 034/024
JS27R - A34 - S15 - 034/024
BH23B - 013/013
BH23G - 014/014
BP23G - 014/014
BH27G - 015/015
BS23H - S13 - 043/043
BS23H - A31 - S15 - 034/024
BS27H - S13 - 044/044
BS23J - S13 - 048/048
BS23N - S13 - 043/043
BS23U - S15 - 034/024
BS23U - A36 - S15 - 034/024
BS23V - A32 - S15 - 034/024
BS23V - A34 - S15 - 034/024
BS23R - A33 - S15 - 034/024
BS23R - A34 - S15 - 034/024
Re: AAR rear springs [Re: 6bblgt] #61326
05/29/08 11:15 PM
05/29/08 11:15 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
All 1970 cars, the spring numbers are listed first;
Edit, new larger list;
013 & 013 - BH23C, JH23B, JH23C,
014 & 014 - BH23G, BH23L, BP23G, BP23L, JH23G, JH23L, JH27C, JH29G
015 & 015 - BH27G, BP27G, JH27G, JH27L
034 & 024 - BS23H, BS23N, BS23R, BS23U, BS23V, JH27N, JS23N, JS23U, JS23R, JS23V, JS27V, JS29U, JS29V
034 & 014 - BS23V (the 1 is likely a typo)
042 & 042 - JH23C,
043 & 043 - BH23G, BS23H, BS23N, BS23U, BS23R, BP23G, BP23N, JH23H, JH23G, JH23L, JH23N, JH29G, JS23N, JS23R, JS23U, JS23V, JS29N, JS29U, JS29V,
044 & 044 - BS27H, BS27N, BP27G, JH23H, JH27H, JH27G, JH27L, JH27N, JS27N, JS27V
048 & 048 - BS23J, JH23J
072 & 072 - VH29B, VL29C, VL29G
073 & 073 - VL41C, VL41G
081 & 081 - VS29H
If anyone has a broadcast sheet for a 1970 Hamtramck car showing a combination not listed above, please scan it and send me a copy?
Barry
Re: AAR rear springs [Re: Alaskan_TA] #61327
05/30/08 12:21 AM
05/30/08 12:21 AM
NoVa
E
ebodyseast Offline
ebodyseast  Offline
E
NoVa
Uh huh - like I said weeks ago, surround your self with the best, you'll get where you want to be. Thanks guys, I bet Moparclown feels the same.
As these are just a bunch of numbers, I'll take the step to try to decipher them.
We see the conv's get the heavier rated 044 springs to their 043 HT counterpart.
We also see that 340 Challenger V8's have 2 springs offered. The 043, that may be original to Moparclown's 340 - I'll go ahead and sign off on that, especially as he feels that they are just that - and the 044 for Conv AND HT. We see NO convs with the 043 springs, as well.
Barry ( ) shows a few 318 cars that came with the 043's that the 383 R/T's & 'Cudas came with, impressive. Even 318 conv's that have the 044 springs, impressed again.
Also seen is that all cars listed lacking S15 susp also lack the 024/034 'Hemi' springs. I think I saw a 340 'Cuda lacking S15 susp...just as was told to me by 70440+6bbl earlier - would be after the period in the model year also mentioned.
Good stuff guys, thanks too to Dan ( ) for his time to help us out here to learn by comparison.
I've only been wrong once. That's when I thought I was wrong....but I was really right! East
Re: AAR rear springs [Re: ebodyseast] #61328
05/30/08 02:56 AM
05/30/08 02:56 AM
cataclysm80 Offline
cataclysm80  Offline
Tav
Re: AAR rear springs [Re: cataclysm80] #61329
06/05/08 08:26 PM
06/05/08 08:26 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Here's the thread conv440, hope it helps.
Careful, your character's showing!
Re: AAR rear springs [Re: mopar346] #61330
06/06/08 11:48 AM
06/06/08 11:48 AM
NW Ohio
6pkaar Offline
6pkaar  Offline
NW Ohio
Anybody know what the arch is supposed to measure on the AAR springs? Where is this measured from, center of eyelets to inside of spring arch?
