aluminum main caps and girdle #613210
02/14/10 12:43 PM
02/14/10 12:43 PM
In the mud somewhere
dodgedude4x4 Offline OP
Has anyone used the 440 source alum caps and girdle?? Looking for info,
528
15.1 comp
turning 7000 rpm
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613211
02/14/10 02:32 PM
02/14/10 02:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Hey, didnt I buy a 400 block off you a few years ago......If your going to look at a girdle, I would quickly get with Greg at BCR and reserve one of his. They are the best no doubt!
Re: aluminum main caps and girdle [Re: joshking440] #613212
02/14/10 02:39 PM
02/14/10 02:39 PM
Yes you did,
My mains arent walking much,(3 and 4 show some transfer) didnt know if i could get by with a less expensive setup? Any info is Greatly appreciated !
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613213
02/14/10 02:48 PM
02/14/10 02:48 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
the problem i see with the other kits is that they require spacers to get the job done. Now your relying on the strength of some spaces. With the BCR kit once you install the mains, you deck the bottom of the block so the mains and block are flat. I know it seems a little pricey, but its not even close to a comparable product. I know how hard you mud guys are on stuff.... especially you....
Re: aluminum main caps and girdle [Re: joshking440] #613214
02/14/10 02:55 PM
02/14/10 02:55 PM
Thanks for the kick in the pants Josh !! Not a place to skimp. Yes i am hard on stuff, But the ferds & chivys guys sure dont like to see the dodges pull in to the tracks !!!
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613215
02/14/10 03:04 PM
02/14/10 03:04 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
i have a 3/8 CRE girdle for a good price.i used it for 2yrs.
Re: aluminum main caps and girdle [Re: blownzoom440] #613216
02/14/10 03:33 PM
02/14/10 03:33 PM
The BCR girdle wont work for me , I need the internal pick-up .
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613217
02/14/10 05:04 PM
02/14/10 05:04 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I had a set of the 440Source aluminum caps. Nice enough pieces.
Re: aluminum main caps and girdle [Re: Stanton] #613218
02/14/10 05:13 PM
02/14/10 05:13 PM
Bcr are out of girdle kits anyway,Dont know if it would have fit my internal pick-up....
Thanks for the replys
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613219
02/14/10 05:25 PM
02/14/10 05:25 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Diablo used a hughes engine girdle on his pull truck and said it done a good job.
Re: aluminum main caps and girdle [Re: mac56] #613220
02/14/10 05:36 PM
02/14/10 05:36 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
I think you can get a thick girdle only from Mancini.
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613221
02/14/10 06:02 PM
02/14/10 06:02 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I used an internal pickup with the BCR cap/girdle sytem The girdle is notched for the pickup but I would have done it myself if it wasn't. I probably would have taken off less material too. FWIW, I think 1/2" thick is about right. Three-eighths seems thin and 3/4" just excess weight. The 3/16" aluminum one on ebay was hilarious.
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613222
02/14/10 06:40 PM
02/14/10 06:40 PM
why not step up to a good block that doesn't need bandaids
Re: aluminum main caps and girdle [Re: @#$%&*!] #613223
02/14/10 07:12 PM
02/14/10 07:12 PM
(I used an internal pickup with the BCR cap/girdle sytem The girdle is notched for the pickup but I would have done it myself if it wasn't. I probably would have taken off less material too)
My mistake , the mancini girdle says external oiling.Bcr said they were out of kits.
Cab, going to limp this block by this year.
Daughter going to collage next year, give me time to gather some Good parts.
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613224
02/14/10 09:42 PM
02/14/10 09:42 PM
northeast texas
strokin73cuda Offline
northeast texas
Awesome pics.
496 stroker,Indy srs , new best 6.87 @ 98 1.46 60'
Re: aluminum main caps and girdle [Re: strokin73cuda] #613225
02/15/10 12:20 AM
02/15/10 12:20 AM
Thanks for all the input.
Some of the mudraces get pretty Nasty !!
Re: aluminum main caps and girdle [Re: dodgedude4x4] #613226
02/15/10 10:22 AM
02/15/10 10:22 AM
Quebec, Canada
Diablo Offline
Diablo  Offline
Quebec, Canada
Like MAc65 said I used a Hughes Girdle on the 496ci 800+hp engine with Alum caps and Alum rods. Turned it past 7000rpm usually and never have seen any signs of walking.
Oh and it has a notch for an internal pick up....
