Re: '73 Charger light problem
[Re: attaboy]
#613092
02/14/10 02:04 PM
02/14/10 02:04 PM
Posts: 329 Orange Park, FL
MRHWS
Orange Park, FL
Thanks, I'll go this route.
1973 Charger SE
1974 Charger Rallye 440 Aztec
2008 Charger SRT8
[Re: MRHWS]
#613093
02/14/10 03:05 PM
02/14/10 03:05 PM
RapidRobert
If you want to diagnose it www.mymopar.com has wiring diagrams for the colors to work on and a parts store circuit tester, the one w the alligator clip on one end of a wire and a light w a thin metal pointer on the other end is the one to use & is only several bucks. I'd check for fire on the particular color wires in the pull apart electrical connector(not the one for the ign but the one for the turn signals/brake lights) keeping both halves still connected & see what you find for opens. If you do purchase a TS harness ahead of time I'd plug it in the connector outside of the column before undoing the steering wheel.
